Driveline BLOWN - JeepForum.com
post #1 of 5 Old 09-05-2012, 11:42 AM Thread Starter
singleytools
Driveline BLOWN
Bought a '98 ZJ with 112K highway miles. Swapped a 3" lift from my '93 to the '98. The first "relatively tame" 4 wheeling I did blew out the front driveling. I discovered the forward end is a CV style and the back is a U-joint style. "Fortunatly" I had difficulty getting someone to rebuild or replace it. I didn't like the idea of a used on. What I found out is the lift compromized the angles of the CV style front. Because of the delay, I found a rebuilder who is replacing the CV style with a U-joint style in the front. The told me that if will be new and much stronger, especially in 4 Wheeling conditions.
Any input from those aware of this condition? Jeep has discontinued this diveline...
singleytools is offline
post #2 of 5 Old 09-05-2012, 12:05 PM Thread Starter
singleytools
Cost for repair
I found 6-States in Salt Lake City to rebuild my driveline for $250 and about $25 in shipping from about 2 hours here in Idaho. The wrecking yards wanted $180 for a used one that would put me back in the same place. They were great with their info. We shall see how it all turns out
post #3 of 5 Old 09-05-2012, 12:20 PM
errorcode3
searching a bit on this forum would have yielded some great info.
Some say a simple 2" BB can destroy the CV front driveshaft, most lift kits actually recommend swapping the CV style for a normal u-joint.
but again, this is pretty typical for the CV style.
98 - Slate 5.niner. minor mods
02 - Silver Liberty (wives mall crawler)
errorcode3 is offline
post #4 of 5 Old 09-05-2012, 12:42 PM
gabrod72
CV style driveshaft blowing up is all part of lifting a ZJ, and they grenade even faster if you take it on the trails. You can find a used one pretty cheap at a u-pull it, so I'm sure if you drive you can locate something to patch it up for now relatively cheap. That stated, you need to start looking for a front yoke and a U-joint front driveshaft if you're going to keep wheeling.
If you're paying your builder make sure they're including and installing the yoke too. Unfortunately, the yoke for the CV and yoke for the U-joints are different, so you absolutely need to change the one on your front axle. There's lots of write-ups on this and it's a relatively simple procedure to DIY. As for having it re-built, for that price I'd spend the extra $25 and just get a Tom Woods shaft.... then install the yoke and DS myself. You will need to find the yoke first to see what the final length will be for your driveshaft though.
_______________________________________________
WARNING: Lo barato sale caro (Cheap things often lead to more expense)
gabrod72 is offline
post #5 of 5 Old 09-05-2012, 12:54 PM
PolkaPower
I blew mine out with a 2" BB. Went to a junkyard and pulled a front U joint double cardon DS from another ZJ and had a shop put a new yoke in. 100 bucks plus 15 for the ds.
PolkaPower is offline
driveline , zj
NP 245 Blown Up Brudus WK Grand Cherokee & XK Commander Forum 5 08-22-2011 06:27 PM
blown up 4.0 Inavacuum ZJ Grand Cherokee Forum 0 02-28-2011 04:01 PM
Blown up 4.7 Brudus WK Grand Cherokee & XK Commander Forum 21 12-29-2010 12:22 AM
blown 96 4.0 what will fit? iamdurkee ZJ Grand Cherokee Forum 7 10-11-2008 05:12 PM
Blown trans quickfix ZJ Grand Cherokee Forum 2 01-22-2008 01:02 PM
