Drive Without Front Driveshaft?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Drive Without Front Driveshaft??
The ULTIMATE "Selectable" Locker System! Brough**Flash Weekend Sale** Rockridge4wd.com Only!RIGID LED Light Blowout Sale - All Sizes, All Series, all
Unread 07-20-2015, 12:06 PM   #1
SunWolf
I have been lurking here for quite a while now, and have learned a ton from you fine folks. I have been able to find the answers to my questions just from searching the forums, so I've only posted twice in the last 7 years. ( good grief, 7 years!?!) Well, I finally found a question I couldn't find the answer to.
I have a '95 ZJ, 5.9l with an NP249. The VC has finally given up the ghost. I have a donor transfer case, a Haynes, a Chiltons, and this forum...and just enough knowledge to be dangerous . Problem is, it is just too dang hot to be out there working on it now. So I'm looking for a temporary work-around. I know on selectable 2-wheel/4-wheel drive vehicles, you can remove the front shaft and drive as 2-wheel drive only. But this stupid Quadra-Trak thing??
TLDR: My question is, "Can I drop the front driveshaft and drive it until the weather cools down in a couple months?? Just short local runs, not driven daily.
'95 GC Limited, stock...
I'm not shy, I'm studying my prey.
SunWolf is offline   Reply With Quote Quick reply to this message
Unread 07-20-2015, 12:13 PM   #2
PolkaPower
If the VC already done for then you won't hurt anything by taking out the shaft. You just need to be real careful where you park because on 93-95 249's front shaft removal can allow the ZJ to roll free. So make sure the e brake works and you chock the tires or something.
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 07-20-2015, 03:17 PM   #3
SunWolf
Awesome, I will definitely remember to park in a safe manner to avoid rolling! Thank you very much.
Unread 07-21-2015, 12:01 AM   #4
tjcustomranger
Mine didnt roll at all for the first week parked in my dads steep driveway and she was gone haha. I daiky mine without the shaft put maybe 5,000 miles on it like that
tjcustomranger is online now   Reply With Quote Quick reply to this message
Unread 07-21-2015, 05:21 AM   #5
jeepjeepster
It wont roll free, but whatever slip the VC still has (and it should still have SOME) will allow the Jeep to roll VERY slowly. Just use the ebrake (you should anyway) and possibly throw a block of wood under the wheel.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 03:16 PM   #6
Adwex
I had the front shaft off my 5.9 for almost a year, parked on a slightly sloped driveway, it didn't roll.
Adwex is offline   Reply With Quote Quick reply to this message
Unread 07-24-2015, 03:25 PM   #7
kg6mov
Hears the voices
kg6mov's Avatar
The second gen 249 is NOT the same case as the first gen 249.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 33's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, Backyard parts fodder
kg6mov is offline   Reply With Quote Quick reply to this message
Unread 07-25-2015, 02:22 AM   #8
PolkaPower
It's fine to remove the front shaft off a 96+ 249 even with a good VC it will not damage it. 93-95 you will ruin the VC by removing the front shaft and it can roll. Like tjcustoms story lmao.
