drive shaft Q - JeepForum.com
post #1 of 4 Old 06-23-2011, 12:17 PM Thread Starter
Darman
drive shaft Q
i have a 95 V8 ZJ orvis with the upcountry package and NP249. Im planning on doing a F>R swap and a 242 TC. I broke my front drive shaft and im wondering if i buy a new stock one if itll work with the F>R swap and 242 TC. if so im also looking for one
thanks
Darman is offline
post #2 of 4 Old 07-10-2011, 03:50 PM Thread Starter
Darman
bump
Darman is offline
post #3 of 4 Old 07-10-2011, 05:00 PM
sadass
Yes and no, It may work for sometime but the problem is the drive shaft you have is probably a CV style or (prop-shaft) front drive shaft,which was used in the v-8's grands . this drive shaft is factory set in length and will not tolerate the change in length required due to the lift . Not as well as the standard U-joint /slip yoke style that the 4.0s came with. at 3.5" you will be pushing it .
As far as will it mate to the 242 transfer case, Yes, All the drive shaft and transfer case combos are inter changeable, meaning the U-joint mate at the transfer case end of the driveshaft is the same size and style with all the combinations. 249,242,231 to CV or U-joint style
A good number of us on here that lifted the v-8 grands have have ditched that cv style and went with the yoke at the diff set up.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #4 of 4 Old 07-10-2011, 05:28 PM Thread Starter
Darman
my stock front drive shaft was u joint style with a double cardan joint in it. I blew the cv ball in the double cardan joint so im looking for a new one but dont want to by a stock one if ill have to change it when i get a lift. Im looking at Rough countrys 4inch long arm lift kit now. will the stock drive shafts work with this?
Darman is offline
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 10:53 AM
Diagnosing a front CV shaft bad on the drive shaft, please help? Jakeb2k4 ZJ Grand Cherokee Forum 6 12-17-2010 06:02 PM
5.9 front cv drive shaft . will a 5.2 shaft work mtx11 ZJ Grand Cherokee Forum 7 01-07-2009 06:39 PM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 10:17 PM
knocking in drive train/ DRive w/o axle shaft? farmerzj ZJ Grand Cherokee Forum 11 04-03-2007 08:11 PM
