drive shaft - Page 2 - JeepForum.com
post #16 of 20 Old 05-26-2011, 07:46 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Originally Posted by Newb1995jeepgc View Post
Everything is fine now. Added Axle Fluid in it and everything is good... good thing it sat for 2 years and leaked out and not driven at all. I drove it for about 2 miles and started to notice the axle starting to whine so i stopped and look... fixed it before any damage was done.
good deal
HighLonesome is offline
post #17 of 20 Old 05-26-2011, 08:05 AM Thread Starter
97ZJ4X4
will a 242 from a 4.0 work in my 5.2?
JEEP: The Import Eater
97ZJ4X4 is offline
post #18 of 20 Old 05-26-2011, 08:17 AM
freakinheep89
Originally Posted by 97ZJ4X4 View Post
skrew that. i guess if thats the problem ill go get a new diff. im not in to spending all that much time and money. and with my luck i would fix it and something else in it would break. at this point im banking on the PO just being a moron and thinking pulling the 4wd would save on gas...
I think you are misunderstanding the VC, its in the transfer case, not the diff. The reason alot of people pull the front shafts when they start whining is because the front axle is a live axle and is always spinning unless you remove the shafts or gears. The VC in the transfer case is probably bad.
Theres a thread at the top of this forum, it will have everything you need for the swap.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #19 of 20 Old 05-26-2011, 08:21 AM Thread Starter
97ZJ4X4
hmm well i had a tranny shop "supposedly" look at my transfer case to make sure all was good. altho they were about as trust worthy as the used car dealership that sold me this POS in the first place so idk... i will look into it tho, thanks for the advice.
97ZJ4X4 is offline
post #20 of 20 Old 05-26-2011, 08:43 AM Thread Starter
97ZJ4X4
ok, so i can get a np231 trans case on ebay for around $300, and i can get a front diff for about the same. my only question now is... how do i kno which one i need to replace?
97ZJ4X4 is offline
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 09:53 AM
Diagnosing a front CV shaft bad on the drive shaft, please help? Jakeb2k4 ZJ Grand Cherokee Forum 6 12-17-2010 05:02 PM
5.9 front cv drive shaft . will a 5.2 shaft work mtx11 ZJ Grand Cherokee Forum 7 01-07-2009 05:39 PM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 09:17 PM
knocking in drive train/ DRive w/o axle shaft? farmerzj ZJ Grand Cherokee Forum 11 04-03-2007 07:11 PM
