drive shaft - JeepForum.com
post #1 of 20 Old 05-24-2011, 07:34 PM Thread Starter
97ZJ4X4
drive shaft
so i got my ZJ last december. it was in pretty good condition, with very few problems.... except one big one. The front drive shaft and drive axles had been removed by the PO. i have two questions. first: what possible reason could they have had to remove them? and second: if i replace the drive shaft with one from a scrap yard, will it need to be balanced or can i pop it right in? thanks for your help guys, cuz im at a loss
JEEP: The Import Eater
97ZJ4X4 is offline
post #2 of 20 Old 05-24-2011, 07:38 PM
Technohead
Most likely removed because the viscous coupling in the transfer case is toast. Common problem for V8 models with 150k+ miles.
-Eric
Technohead is offline
post #3 of 20 Old 05-24-2011, 07:40 PM
TallyZJ
And/or the front gears are toast and he removed the axle shafts and the drive shaft so the pinion wouldn't turn.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #4 of 20 Old 05-24-2011, 07:57 PM
freakinheep89
Thats more of what I was thinking.
The VC will wear down the pinion bearings much faster from the added strain, and once they start whining and grinding some people just take out the inner shafts and leave the outers so the pinion wont turn.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #5 of 20 Old 05-24-2011, 08:10 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
this,
and when a VC goes bad, you are in parttime 4wd. Not good on asphalt. Accelerated wear on the entire drivetrain.
HighLonesome is offline
post #6 of 20 Old 05-24-2011, 08:28 PM
Newb1995jeepgc
1994 ZJ
Mine has 184000 and my vc are kinda still good... not binding but they do whine... or the front end does because the PO forgot to put oil in my front axle. It was bone dry almost when i finally checked it.
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #7 of 20 Old 05-24-2011, 08:48 PM
HighLonesome
Remind me not to buy your ZJ.
post #8 of 20 Old 05-25-2011, 07:31 AM Thread Starter
97ZJ4X4
uhg. i hope not. im not sure i got the money for new gears
97ZJ4X4 is offline
post #9 of 20 Old 05-25-2011, 07:32 AM Thread Starter
97ZJ4X4
how hard is that to replace?
97ZJ4X4 is offline
post #10 of 20 Old 05-25-2011, 08:34 AM
biggoofy
just swap it out for a 242 or 231.
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #11 of 20 Old 05-25-2011, 05:41 PM
TallyZJ
That is what I would do
TallyZJ is offline
post #12 of 20 Old 05-25-2011, 07:17 PM Thread Starter
97ZJ4X4
awesome!... so does anyone have one layin around i could have. lol. but really, id rather fix what i got.
97ZJ4X4 is offline
post #13 of 20 Old 05-25-2011, 07:40 PM
Newb1995jeepgc
1994 ZJ
Everything is fine now. Added Axle Fluid in it and everything is good... good thing it sat for 2 years and leaked out and not driven at all. I drove it for about 2 miles and started to notice the axle starting to whine so i stopped and look... fixed it before any damage was done.
post #14 of 20 Old 05-25-2011, 10:45 PM
freakinheep89
If you are actually going to fix the 249, a new VC can be had on ebay for around $300, and its not too hard to install but its not like changing a starter either. very time consuming.
TJ-
post #15 of 20 Old 05-26-2011, 07:43 AM Thread Starter
97ZJ4X4
skrew that. i guess if thats the problem ill go get a new diff. im not in to spending all that much time and money. and with my luck i would fix it and something else in it would break. at this point im banking on the PO just being a moron and thinking pulling the 4wd would save on gas...
97ZJ4X4 is offline
Replacing WJ Front Drive Shaft with Junkyard Shaft? Jonny5alive ZJ Grand Cherokee Forum 4 03-13-2011 09:53 AM
Diagnosing a front CV shaft bad on the drive shaft, please help? Jakeb2k4 ZJ Grand Cherokee Forum 6 12-17-2010 05:02 PM
5.9 front cv drive shaft . will a 5.2 shaft work mtx11 ZJ Grand Cherokee Forum 7 01-07-2009 05:39 PM
Replacing the front drive shaft (CV) to a U-joint style shaft? Bryson ZJ Grand Cherokee Forum 1 08-12-2007 09:17 PM
knocking in drive train/ DRive w/o axle shaft? farmerzj ZJ Grand Cherokee Forum 11 04-03-2007 07:11 PM
