Drive chain wobble under load - JeepForum.com
post #1 of 11 Old 04-01-2013, 12:56 PM Thread Starter
AAK11
My 98 Grand Cherokee 5.2 is out of balance under load, even relatively small uphills creates the vibration.
In neutral or downhill it's quiet.
How can I isolate the culprit? Can I remove the front drive shaft, or the rear one and test drive the Jeep?
I'm hoping it's just a u-joint or the double cardan. Could it be the transfer case?
I just want to fix the part that needs it, not refresh both drive shafts if we can avoid it.
Thanks
AAK11 is offline
post #2 of 11 Old 04-01-2013, 01:12 PM
AnotherRedZj
if its not happening while in neutral, even reving it high, then it seems it would be a moving part. check both motor mounts and tranny mount first, then move on to drive shafts.
could also be under powered, check all plugs and wires, cap and rotor.....make sure your firing on all cylinders.
AnotherRedZj is offline
post #3 of 11 Old 04-01-2013, 01:15 PM
AnotherRedZj
also. if your driving a 98 GRAND cherokee......its not an xj.......its a zj
post #4 of 11 Old 04-01-2013, 02:14 PM
Corrupt
You can remove your front drive shaft and drive it around. If the vibration is still there then you know it's not the front drive shaft and you can continue looking elsewhere.
***If you try to fail and succeed, then which have you done?
***RIP Ratmonkey!!***
Corrupt is offline
post #5 of 11 Old 04-01-2013, 10:56 PM
dnuccio
you can remove the rear driveshaft and drive it as well, just go easy on the skinny pedal.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 11 Old 04-02-2013, 06:19 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Then be sure to refill the transfer case after all the fluid drains out the back.
Can't remove the rear shaft.
ratmonkey is offline
post #7 of 11 Old 04-02-2013, 06:23 AM
AnotherRedZj
This.
post #8 of 11 Old 04-30-2013, 07:12 PM Thread Starter
AAK11
Still looking for the problem. With front drive shaft out, it still shows the vibration.
Fresh u-joints and balancing on the rear drive line didn't help.
I think I'm down to a few possibilities:
AAK11 is offline
post #9 of 11 Old 04-30-2013, 08:05 PM Thread Starter
AAK11
1- transfer case (replaced with a used unit a year ago)
2- rear differential
3- wheel bearing
4- transmission/motor mounts
The vibration is a little at idle, but shows up on acceleration, especially under load uphill.
Engine speed and vehicle speed don't seem to have any influence.
Anyone have a good idea?
Thanks.
AAK11 is offline
post #10 of 11 Old 05-28-2013, 08:20 AM Thread Starter
AAK11
Bmeyst is correct.
The ignition system was worn out. New cap, rotor, plugs and wires solved the problem completely.
thanks.
AAK11 is offline
post #11 of 11 Old 05-28-2013, 06:01 PM
AnotherRedZj
YAY!
I helped!
drive shaft , u-joints , vibration
