The Dreaded STALL - JeepForum.com
post #1 of 8 Old 06-29-2013, 09:30 AM Thread Starter
cberry05
The Dreaded STALL
I have a 96 Jeep Grand Cherokee 5.2L V8. I have had the stalling issue everyone seems to have. I have a check engine light on for the crank sensor... Replaced it and the Camshaft sensor. When it wouldnt crank up, I replaced the fuel filter, started right up. So now im at a check engine light for two things I have already replaced, Afghanistan did not stress me out as much as this jeep... Any ideas from anyone who may know what the issue is?
cberry05 is offline
post #2 of 8 Old 06-29-2013, 09:39 AM
ZeeJay1997
Hey welcome to the forum and thanks for your service. I joined the forum for the same reason you did and so did a lot of other people.
Click on the green link below for everything i know about fixing a stall without spending a lot of money.
ZeeJay1997 is offline
post #3 of 8 Old 06-29-2013, 04:46 PM Thread Starter
cberry05
Thanks much, I appreciate it. Its been a struggle with this thing, I think everyone at work is tired of taking turns following me home so I don't get wiped out in an intersection
cberry05 is offline
post #4 of 8 Old 06-29-2013, 06:45 PM
dusterdude
What brand crank sensor
dusterdude is online now
post #5 of 8 Old 06-29-2013, 11:14 PM Thread Starter
cberry05
BWD I believe it is.
cberry05 is offline
post #6 of 8 Old 06-30-2013, 06:54 AM
ZeeJay1997
Verify 5 volts at the TPS across the two outside pins on the connector. Disconnect TPS, turn key on and read the voltage. This supply voltage from the PCM is shared with the CKP and CPS. If it is good, double check the connections to the sensors.
Some people have had bad luck with the BWD sensors.
post #7 of 8 Old 06-30-2013, 10:43 AM
PolkaPower
Use Mopar parts for the sensors. The aftermarket parts can act bad right out of the box for ZJ's. Go to a JY and pull one for cheap to see if that is the problem.
PolkaPower is online now
post #8 of 8 Old 06-30-2013, 04:40 PM
dusterdude
