DRBII Alternatives? - JeepForum.com
post #1 of 3 Old 02-13-2012, 08:59 PM Thread Starter
Lakoswolf
DRBII Alternatives?
Greetings everyone,
I've been looking around and it would seem that DRBII scanners are becoming a scarce item. Does anyone know of any third party alternatives given the age of the technology? I have access to a snap-on scanner (and I know about the code grab via the MIL/CEL on my '93 ZJ) but so far as I know those are only good for OBDI & OBDII. From what I've seen DRBIII would be far too expensive, and I'm not entirely sure that it's backwards compatible. I would rather bulk up my toolbox than pay the dealer should I need to pull an SRS or ABS etc. code in the future.
Thanks
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #2 of 3 Old 02-13-2012, 10:06 PM
AVR2
I asked a while back if there were any software-based DRB-II scanners which would run on a laptop, such as you can get for OBD, but there was nothing. It looks like the only option is to find a professional unit.
According to the DRB-III manual, it's designed to work with vehicles from 1994 onwards, but is hardware-capable of supporting older vehicles. I think that means that to use it with a 1993 ZJ you'd have to have the relevant plug-in firmware module. The biggest problem though, as you say, is the price.
If you just want to bleed the ABS system, you can also use the Thexton 133 or Ford t90p-50-ala. These aren't scan tools, they plug directly into the ABS system via the ABS computer connector and cycle the valves to flush any trapped air out of the system. Back in 2006 you could get a Thexton for under $60.
AVR2 is offline
post #3 of 3 Old 02-17-2012, 08:40 PM Thread Starter
Lakoswolf
Thanks for the info. I wanted to snag the DRB for versatility, but that's good to know about the breaks seeing as I'll probably be doing that soon.
code , drbii , zj
possible cv driveshaft alternatives? paulwaller ZJ Grand Cherokee Forum 1 10-16-2011 01:42 PM
Ball Joint alternatives overboostin WK Grand Cherokee & XK Commander Forum 7 01-31-2011 08:04 PM
Vehicle Information Center Replacement/Alternatives Stoneync ZJ Grand Cherokee Forum 9 09-08-2010 08:18 PM
Alternatives to Hi-Lift ben_wagner ZJ Grand Cherokee Forum 15 07-02-2007 12:25 AM
