Double Cardan U-Joint...Removal? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Double Cardan U-Joint...Removal?
Income tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!
Unread 04-30-2008, 11:14 AM   #1
Jsun
Hi all,
I had other intentions on fixing up my Jeep, but now I'm just fixing it. I had a bad squeal comming from under my ride. Took out the front drive shaft to learn that the noise went away. Inspected the Double Cardan U-joint and noticed the the center ball seal and such were a mess.
I tried following several write-ups on the removal process such as:
http://www.stu-offroad.com/axle/driv...iveshaft-5.htm
http://www.jeepforum.com/forum/f11/cv-driveshaft-rebuild-part-deux-345170/
I can't seem to remove the first u-joint from it's location. Can someone please help shed some light here. I've used a 19mm socket to try to hammer it out after removing the retaining clips. Do I have to some how remove the caps before it can be removed from it's housing? I'm worried I 'll wreck the u-joint trying to remove the center ball. I know having the right tool for the job helps, but others have done this with just a hammer and socket???
Thanks in advance!
95 GC Ltd. V8
(in search of a owners manual)
"It aint no thang but a "Jeep" thang baby..."
Jsun is offline   Reply With Quote Quick reply to this message
Unread 04-30-2008, 11:20 AM   #2
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i did it with a hammer and socket, get some PB blaster, and a bigger hammer.\
good luck mate.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/...ndard-1056365/
5.9 ANDY is offline   Reply With Quote Quick reply to this message
Unread 04-30-2008, 12:21 PM   #3
Jsun
good luck mate.
Thanks! So I can just pound on the cap to push it through? It seems that the part that mates up with the TC mounting gets in the way to let the pin travel through. It's almost out on the side i've been hitting. but do I just try to pull it out once one side is free?
Thanks again...
95 GC Ltd. V8
Unread 04-30-2008, 01:14 PM   #4
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
wait, the shaft isnt out on the ground?
Unread 04-30-2008, 01:53 PM   #5
Jsun
LOL...yes the shaft is removed. I'm talking about the piece that would mate to the TC if it were mounted. It seems to get in the way for full travel of the pin as it hits against the housing...
95 GC Ltd. V8
