Door Won't Lock/Unlock - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Door Won't Lock/Unlock
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 12-06-2007, 05:15 PM   #16
colinzj
2006 WK
Usually you can get the lock unstuck, but you'll want two people.
Position one person on the outside. They need to push the door into the body as far as possible. Position the other person on the inside. While the person outside is pushing, the inside person needs to unlock the door by hand.
This works on ZJs as well. Obviously it won't help if the lock rod has somehow wedged itself against part of the door frame, but if it's just the mechanism acting up, I've used it successfully a dozen times.
If you absolutely can't come up with a helper, it's possible but nowhere near as easy to do it yourself by grabbing the armrest with one hand and doing the lock with the other.
colinzj is offline   Reply With Quote
Unread 12-06-2007, 09:47 PM   #17
xwhizx
Ok i got the panel off!! But now I've got a bigger problem...its the actual lock I think. How the hell can I override it to UNLOCK so I can remove it?? The door is shut and it is in the locked position. If I tug on the gray bar, its like it doesn't even move. I can't pull it hard enough to force the unlock. Suggestions?
xwhizx is offline   Reply With Quote
Unread 12-06-2007, 10:20 PM   #18
BucYouUp68
Soak it with Marvel Mystery oil, It will budge.
Why is there a fish finder in your Jeep?
Not hard, if you have a socket wrench and the mental capacity of a ham sandwich.
BucYouUp68 is offline   Reply With Quote
Unread 12-07-2007, 06:31 AM   #19
xwhizx
Can you be a little more specific? What part should i soak? I can BARELY see the backend of the lock.
Unread 12-07-2007, 02:41 PM   #20
xwhizx
There seems to be NO WAY to unlock the latch keeping the door closed. Does anyone know an "override" tip to get it to unlock?
Unread 12-07-2007, 03:08 PM   #21
BucYouUp68
Just soak the whole mechanism with fluid, let it sit and try to work the lock back in fourth.
Unread 12-08-2007, 01:59 PM   #22
xwhizx
I have FIXED the door. Thanks to everyone who helped!
SOLUTION:
I had someone pull as hard as they could on the LOCK gray bar as I pulled on the handle outside, and the door came open. Took out the acuator and found out that one of the gears controlling the lock portion was bent. Instead of trying to bend it back and cause further problems, I decided to replace the entire actuator. Online I found it for $50+ shipping, but the local dealer here had it for $70 including tax. So I got it from the dealer and put it in. Works great!
Thanks again!
