Quantcast Door will not open - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Door will not open
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 01-31-2009, 12:56 PM   #1
zj95
Door will not open
In an attempt to fix my rear passenger door PL I have managed to unable the door completely.
Steps I took to get there.
1. Removed door panel and latch.
2. Took latch apart, cleaned and lubed
3. Reinstalled latch and rods, all felt well.
4. Closed door to test.
I must have put the child safe switch to unable the interior door handle. The outside door handle is not opening the door either. I can feel the exterior handle move the rod it is supposed to, but it does not open the door. I have played with the lock and nothing works.
Does anyone know how to get it open? I did not reinstall the interior door panel so I still have access from the inside.
This is what I get trying to knock out a task quick while the baby naps!!
95 ZJ Loredo
zj95 is offline   Reply With Quote
Old 01-31-2009, 01:54 PM   #2
elmer_fud
if you still have the interior pannel off, you should be able to reach in and pull part of the latching mechanism. One of the connections you pull should open the door. If you know where the exterior handle is supposed to be connected I would start there.
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote
Old 01-31-2009, 06:26 PM   #3
zj95
I worked all of the rods from the interior. I was able to flip the child lock as well and no dice. Whatever I did to the latch mechanism, it didn't appreciate it.
I took off the panel behind the door and can see the bolts and plate for the striker. I am going to grind the plate and bolts off at the sheetmetal and hope that the sriker will just come with the latch when I open the door.
Does anyone have a striker and bolts laying around from an old rig to sell cheap?
Old 01-31-2009, 11:03 PM   #4
elmer_fud
maybe try jamming the door in a bit, and see if it will give the latch a bit of room to shift, then try opening it. If not sounds like drilling the bolts out would work
Brian
Old 02-08-2009, 08:33 PM   #5
zj95
Well I got it open in time to go to the Parker 425. There where a few nice ZJs and WJs around.
I removed the side panel behind the door and removed the seat belt. I had to remove a little sheet metal to get at the bolts. Bolts cut off easy enough and I was able to open it with the striker still attached to the door. Cut the striker apart so I could remove the lock/latch mechanism and replaced with new. Glad I picked up a new striker while I was at the 4x4 yard. That door latch was not going to let go!.
So the lesson is, watch youreslf when you try and rebuild your locks!!
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
