Door problems. - JeepForum.com
post #1 of 18 Old 01-09-2013, 06:40 PM Thread Starter
Carroll182
1994 ZJ
Door problems.
So its always popped when i open it... i let it go for too long obviously.
I figured it was a pin, so i went and bought them today, took the door off, started replacing pins, then noticed that the weld is shot on the bottom hinge.
How do I go about getting this fixed? Just reweld it? What if it isnt lined up correctly? JB Weld it and tinker until its straight and then weld it once i know its in position?
Hope someone can chime in.
Thanks.
Carroll182 is offline
post #2 of 18 Old 01-09-2013, 06:59 PM
papitt
I'm going to subscribe to this because ''yes'' mine does it also..
I've been to lazy to ask how to fix them. I've read the repairs years ago .. and I think I've seen it done in one of the body shops I called on years ago .
... I'm thinking that the door it's self breaks and then flexes up and down .. But I kind of think mine is in the hinge or bushing & pins.
papitt is offline
post #3 of 18 Old 01-09-2013, 07:07 PM
wcf59
I just got a price quote to have this done at a local body shop. Just over a $100.00 to re-bush both hinges.
wcf59 is offline
post #4 of 18 Old 01-09-2013, 10:49 PM Thread Starter
Carroll182
1994 ZJ
$100 bucks huh?... Thats not bad, was going to go look at a 5.9 Tomorrow to replace...
post #5 of 18 Old 01-10-2013, 10:45 AM
xcaliber81
i drilled some holes and bolted the hinge on cause mine did this also, problem solved, if you want i can upload a pic. I rebushed and pinned my hinges myself and it cost like 15$ each door.
xcaliber81 is offline
post #6 of 18 Old 01-10-2013, 01:16 PM Thread Starter
Carroll182
1994 ZJ
Pics would be great.
post #7 of 18 Old 01-10-2013, 02:12 PM
xcaliber81
k, i planned it as a temp fix but it works good however the door need to come off since i was doing the pins and bushings it was no big deal.
post #8 of 18 Old 01-10-2013, 04:01 PM Thread Starter
Carroll182
1994 ZJ
Cool thanks. I was going to try some job weld but don't know if it would be enough to support the pressure in opening and closing.
post #9 of 18 Old 01-10-2013, 04:40 PM
xcaliber81
here you go
post #10 of 18 Old 01-10-2013, 06:31 PM Thread Starter
Carroll182
1994 ZJ
Awesome, and that worked good I assume? Plenty of clearance with the door panel off to do this as well?
post #11 of 18 Old 01-10-2013, 06:57 PM
xcaliber81
yeah it works great and there's lots of room behind the pannel, however you will need to do this with the door off because you have to drill from the outside going in.
post #12 of 18 Old 01-10-2013, 08:06 PM
wcf59
Did anyone have trouble aligning the door after taking it off to re-bush the hinge pins? How did you do it?
wcf59 is offline
post #13 of 18 Old 01-10-2013, 08:25 PM
xcaliber81
no alignment necessary remove the 4 bolts facing back and replace the pins, bolt right on. If you have to align the door the fender/s have to come off so you can access the rear part of the hinges.
post #14 of 18 Old 01-11-2013, 04:02 AM Thread Starter
Carroll182
1994 ZJ
I was wondering about the aligning thing myself... but i guess as long as the hinge is welded/bolted down tight, and not flexing, the doors will have no problems.
post #15 of 18 Old 01-11-2013, 08:38 AM
xcaliber81
well its not just that easy you need somebody helping you those doors weigh about 100lbs each and you need to remove the harness, but quite literally you unbolt it and bolt it on.
