Door Panel Trim lights on and Battery Dies - JeepForum.com
post #1 of 7 Old 10-14-2013, 09:06 PM Thread Starter
joe19934
I have a 98 Jeep Grand Cherokee and the Battery died several times since I got it. ( I think the BCM is not going into sleep mode )
Last week I noticed the red light for the alarm set on the dash using the remote and the battery didn't die over the past few days now today I noticed the red light wont go on with the remote and I noticed to door panel lights where the locks and windows controls are on.
I noticed with the key out of the ignition and the drivers side door open you can raise and lower the window.
I know you shouldn't be able to do that.
I would think the BCM is not going to sleep.
I searched and found it may be the lift gate switches....
Any ideas how to verify which is bad other then the domes not coming on ?
What steps should I take to figure this out ?
Does anyone have a location and photo for the BCM...
What inputs does the BCM need to go into sleep mode and allow factory alarm to arm as its not at the moment and killing the battery.
Thank you for any help in advance.
If You can't Go Around It then Go Over It !!!!!!!!!
joe19934 is offline
post #2 of 7 Old 10-15-2013, 05:17 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
There is a delay kind of feature on the raising and lowering the windows,mine has always done that. But it usually times out. I've got to go to work right now. You can read amp draw at the battery to determine if the BCM is going to sleep.
Originally Posted by HighLonesome
coralman is offline
post #3 of 7 Old 10-15-2013, 05:26 AM Thread Starter
joe19934
I looked this morning and the lights on the window and door locks and mirrors buttons were still on so I am sure the BCM is not going to sleep. Beside door ajar and liftgare switches is there anything else say like a switch on the locks? The interior lights are off.
joe19934 is offline
post #4 of 7 Old 10-15-2013, 04:12 PM
coralman
coralman's Avatar
Since you are alarmed there are key switches that click onto the back of the lock mechanism. I don't know that they would do what you are experiencing. But they do override the fob I believe it the locks are actuated. Simple enough to test as there is a connector towards the latch end of the door. Disco battery,separate the connector, and ohm while operating the locks. As an alterternative you could backprobe at the door harness after separating that connector.
Name:  lock switches.jpg
coralman is offline
post #5 of 7 Old 10-15-2013, 07:42 PM Thread Starter
joe19934
Attachment 760289
Thank you Coralman I think I found the issue the Switch for the liftgate was starting to come apart.
I saw that somewhere in another post. For now I compressed it with a C-clamp and took an automatic center punch and peened the metal over the plastic part of the switch to keep it from coming apart again.
The other thing I think I was doing to keep it from going into sleep mode was a simple mistake but a big one - I'm not used to the ignition so I am sure I was leaving it in ACC and not turning the Ignition completely off.
Good thing is while trying to figure out the issue I found the BCM LOL
joe19934 is offline
post #6 of 7 Old 10-16-2013, 04:22 AM
coralman
coralman's Avatar
Glad you got it !
coralman is offline
post #7 of 7 Old 10-16-2013, 09:07 PM Thread Starter
joe19934
Glad you got it !
Thank you again so far so good, I still have a flashing red light on the dash
joe19934 is offline
