Door Lock Interface, DEI 455T - JeepForum.com
post #1 of 12 Old 12-17-2011, 08:04 PM Thread Starter
jmonty0523
I had one hard time finally finding one of these, been searching Ebay for probably around a month or so...
Well, 3 finally appeared. I figured I'd share my find for anyone else looking...
http://www.ebay.com/itm/DEI-455T-Jee...item2c619b3f3f
It's the module you need to wire a aftermarket remote start kit into the power door locks on a '96, '97, '98 Grand Cherokee....
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #2 of 12 Old 12-18-2011, 05:01 PM
JeepFreak1982
You can do a remote start with out it you just gota know what your doing. Really not all that hard to get around it.
JeepFreak1982 is offline
post #3 of 12 Old 12-18-2011, 06:15 PM Thread Starter
jmonty0523
I know, I just can't find out how exactly to do the wiring and put in the relays for the door locks....
...________oooo_
post #4 of 12 Old 12-18-2011, 06:26 PM
JeepFreak1982
You dont need relays. Im a long time installer and have learned A LOT of tricks over the years. To disarm the OEM alarm you just tie the "disarm" wire from the remote start into the purple/yellow wire in the drivers door harness. That will disarm the OEM alarm when you remote start the jeep or unlock the doors. For door locks you open up the lock switch in the drivers door and solder a pair of wires right to the circuit board. All your doing is simulating your finger pushing the button. You have to solder to the 2 leads that come from the switch and go to the circuit board. Just a normal - signal.
post #5 of 12 Old 12-18-2011, 09:40 PM Thread Starter
jmonty0523
Wow, thanks. Everyone else had told me that I needed either the module or a complicated wiring system because of how the key fobs need to get programed... I know I dont need to worry about an alarm, I lucked out and don't have one...
Well I guess it's too late now... I already got the module... Hopefully this will help the next person who is working on this...
...________oooo_
post #6 of 12 Old 12-19-2011, 04:20 PM
JeepFreak1982
Everyone told you that cause they havent been doing this like i have lol. When you do this day in and day out since 1999 you tend to learn a few tricks.
post #7 of 12 Old 12-22-2011, 08:44 AM
dmxsoulja3
I have one of the 455T's that I stashed a while ago incase I ever wanted to do alarm/remote start, does anyone have any tips on what wires are used and not needed with it?
dmxsoulja3 is offline
post #8 of 12 Old 12-22-2011, 12:00 PM
ccoston
Good find. If you have to do relays like I did, it's two relays in each door. Found a diagram on the Audiovox website (I was surprised too!) that worked fine.
ccoston is offline
post #9 of 12 Old 02-14-2013, 11:38 AM
Tourist
I'm sorry for ressurecting an old thread, but JeepFreak could you PM me some more detailed instructions as to how one goes about bypassing the need for relays on the reverse polarity door locks? I've got a 96 Grand Cherokee that had an aftermarket keyless entry system installed. The previous owner replaced the door and did not have the relays transferred into the new door so I'm trying to see if I can get it work as cheaply as possible
Tourist is offline
post #10 of 12 Old 02-14-2013, 11:47 AM
RevZJ
RevZJ is offline
post #11 of 12 Old 03-07-2013, 08:14 AM
cmyers1977
more info
I am working on my 96 grand cherokee and would like some more information. is this going to work as positive trigger? negative trigger? any more info on this would be helpful. I knew someone had to figure this out as they can all be unlocked from one switch.
cmyers1977 is offline
post #12 of 12 Old 03-07-2013, 10:57 AM
RevZJ
5 wire.
MECP Advanced
RevZJ is offline
Heads up! Hard to find 455T MeanGreenZJ ZJ Grand Cherokee Forum 0 09-26-2011 02:10 PM
Power door lock motors work but no lock! lasvegas ZJ Grand Cherokee Forum 2 10-25-2009 12:29 PM
Rear Door Lock Stuck-Door wont unlock automatically jeepergirl19 ZJ Grand Cherokee Forum 1 12-04-2007 08:52 AM
Location Of Door Lock Interface Module? E55&98 Jeep ZJ Grand Cherokee Forum 1 10-30-2006 05:03 AM
Power Door Lock Buzz / Door Lock Duck Noise - Power Door Lock Actuator Solution Coppell-Jeep ZJ Grand Cherokee Forum 4 01-11-2006 10:25 PM
