Door jamb switch does not work - Too little plunger travel - JeepForum.com
post #1 of 3 Old 09-23-2013, 07:23 AM Thread Starter
Bale
Hi guys!
An annoying problem just surfaced. One of the door switches will not turn off the dome lights (and the "door ajar" warning message) when the door is closed. The plunger travel is suddenly a tiny bit too little when the door is closed.
It started after a seat belt buckle was jammed in the door, and maybe did something funny to the switch.
The switch w./plunger looks OK, but I notice that on the other doors the tip of the plungers seem to be raised a bit from the cylindrical part. Does this mean that the plungers are length adjustable? And that the jammed buckle messed with the problem switch?
Anybody know if these plungers are indeed adjustable, and if so, how to adjust them? Looks like pretty fragile plastic, so I don't want to break anything...
1998 ZG (ZJ) Grand Cherokee Ltd, 4L 4x4
Bale is offline
post #2 of 3 Old 09-23-2013, 10:50 AM
darkhelmet
They are length adjustable but mine kept collapsing in... I took a penny and glued it to the door where it hit the plunger...
And yes I have repaired the door hinges and adjusted the striker to pull door in further
98 Grand Cherokee 5.2l converting to a cheap trail rig
http://video.adultswim.com/robot-chicken/our-newest-member-calvin.html
ZJ's: If you dont know what it is you cant afford it.
darkhelmet is offline
post #3 of 3 Old 09-24-2013, 01:48 PM Thread Starter
Bale
I taped something to the door as well, but it doesn't look too sophisticated
Do you know how the plunger length adjustment works?
Bale is offline
