Door Hinge - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Door Hinge
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 02-28-2006, 06:19 PM   #1
rwild
Door Hinge
Has anyone ever changed the door hinge pins and bushings on a ZJ and if so how difficult is it thanks for the info
rwild is offline   Reply With Quote
Unread 02-28-2006, 06:23 PM   #2
driabyor
1994 ZJ
I did it was a pain ... I just chiseled the tops off then drove the pins out. one at a time..
However it may not be the bushings ... Mine was actually the weld .. It had broke... I drilled a hole in the center of the door hinge then put a big washer behind the hinge on the inside of the door.. it work for a temp fix...
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote
Unread 02-28-2006, 06:42 PM   #3
rwild
On mine Im sure its the bushings that are gone. How did you flatten out the narrow ends of the pin? Thanks for the help.
Unread 02-28-2006, 06:46 PM   #4
Stocker
Try this old JU thread -- helped me do mine. http://www.jeepsunlimited.com/forums...t=hinge+ pins
It's probably just bad bushings in the lower hinge (you need 2 per hinge), but you will need a new pin.
Edit: it has been quite a while since I did mine, and it's still good, but I have to scratch my head to recall details. I did not need to unbolt the hinge. It's a bit tight, but not too difficult. I used a small 'ball' type grinding stone in my drill instead of a Dremel. If you have any questions, I will do my best to help!
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline   Reply With Quote
Unread 02-28-2006, 07:00 PM   #5
rwild
Thanks for the info that thread deffinately gave me the courage to do it.
Unread 02-28-2006, 09:06 PM   #6
driabyor
1994 ZJ
i cut mine with a chisel....
be sure and put something under the door to support it.. a jack or some blocks....
The pins and bushing are hard to find.. well at least around here... the stealer wanted 60+ bucks for a hinge.. I dont remember which one it is but ... They offer a pin for one , and the other one is the whole hinge ...
The HELP Parts dont have the exact one either, but with a little research I found one that was close enough... The diameter is the hard match.. The ones that I found were .001 smaller than what suposed to be in the hinge.
5.2 liter 242 :)
Unread 02-28-2006, 09:42 PM   #7
Stocker
Should not be hard to find, try your dealer or email Nick. Pin p/n is 55076192, bushing p/n is 55074591.
Stocker
Unread 03-01-2006, 05:23 PM   #8
02Lightning
I replaced mine and just ground the heads off of the pins. Wasn't too bad.
1995 Jeep Grand Cherokee Limited 4.0L NP249 Transfer Case 196,000 miles
2002 F150 Lightning 385 hp
1969 Mustang Mach 1 428cj 4-speed 3:89 gears
02Lightning is offline   Reply With Quote
