Door Harness Replacement - JeepForum.com
post #1 of 5 Old 11-28-2012, 11:40 AM Thread Starter
squazz
So I got aggravated that the windows quit working & took a razor blade to the boot and wire harness. Got the windows up , but now I got a load of wires that are trashed .
where dose the harness disconnect in the loom for both driver and passenger door? Gonna hit the JY for a replacement
squazz is offline
post #2 of 5 Old 11-28-2012, 12:37 PM
Lakoswolf
The connector from the rest of the vehicle to the harness should be just inside the "frame" of the vehicle a little ways. I was able to pull mine out easily. I used a zip-tie so I didn't lose the other end of the vehicle wiring in the frame.
"Those who say it cannot be done should not interrupt the one doing it." -Chinese Proverb
93' Grand Cherokee 5.2 Ltd. - Mine
93' Grand Wagoneer 5.2- Dad's
93' Grand Cherokee 4.0 Ltd. (Deceased)
Lakoswolf is offline
post #3 of 5 Old 11-28-2012, 06:21 PM
xcaliber81
its right beside where the harness goes through the body, on the passenger side its a little more hidden, i had to remove the plastic thing that all the harness clip into the big one lol best way i can describe it. I replaced my drivers side harness it was easy peasy. I stumbled upon my broken wires by accident re-adjusting my boot also don't forget the torx in between the harness where it goes through the door it took me a while to figure that one out.
xcaliber81 is online now
post #4 of 5 Old 02-18-2013, 04:15 PM Thread Starter
squazz
driver side harness form 94 with security,was easily removed plugs behind the hood release. now my 93 has no security but i don't foresee it being a issue. Passenger side looks more involved (ran out of light)
squazz is offline
post #5 of 5 Old 02-18-2013, 06:04 PM
xcaliber81
Yea the passenger side is a bit more involved but not by much. The drivers side is much easier to remove
