Door handle sticks - JeepForum.com
post #1 of 4 Old 05-24-2011, 03:24 PM Thread Starter
Buzz98zj
Door handle sticks
The drivers side exterior door handle button sticks in when you open the door. You have to wiggle it around so it pops out to shut the door. I was thinking spray it down or replace it. Any quick fixes?
Buzz98zj is offline
post #2 of 4 Old 05-24-2011, 04:10 PM
LordHobbit
WD-40.
You'll probably have to pull it off completely and clean it up then relube. I've got to do this with my drivers side rear door.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #3 of 4 Old 05-25-2011, 10:28 AM
tcar
Originally Posted by LordHobbit View Post
WD-40.
NO.... has nothing to do with the handle itself. Don't have to remove anything.
Do the following with the windows UP.
Open the door, there is an oval rubber plug on the back edge of the door. Pry it out.
Spray the linkage inside the door liberally with WD-40 through the hole.
Do all four doors.
Actually, the rear doors don't have the rubber plug, just the opening (at least mine doesn't).
It will be a lot worse when it gets cold.
(If you forget and leave the window down, you'll have WD-40 all over the glass.)
00 Limited 4.7 V8 SelecTrac
94 Limited V8 SelecTrac
98 5.9 Platinum
95 Limited V8
tcar is offline
post #4 of 4 Old 05-25-2011, 12:32 PM
LordHobbit
Awesome. Thanks
door handle converson wild_jeep ZJ Grand Cherokee Forum 2 07-17-2009 09:50 PM
WJ exterior door handle crashcraddock ZJ Grand Cherokee Forum 5 05-29-2009 09:47 PM
Getting Wax Off Door Handle rckclmer ZJ Grand Cherokee Forum 15 09-01-2008 11:03 PM
Leaking door handle 1999WJMIKE ZJ Grand Cherokee Forum 4 10-18-2007 11:55 PM
Need interior door handle.... razzergreen ZJ Grand Cherokee Forum 2 08-11-2006 11:30 AM
