10-17-2006, 07:24 AM
#1
Well there have been things I have done to my Jeep that worked out really well or were a non-issue and just worked as they were advertised, and then there are those things that are nothing short of a nightmare.
My K&N FIPK has given me nothing but trouble since I bought it; first off I spent a lot of money but thought it was worth it. (I bought into the hype) secondly I thought the thing would provide more power etc but at most it really just makes noise (Which is ok) but I have had it on my 96 5.2 and now my 98 5.9 and it just doesn't measure up to all the hype. Of course there is the filter testing that has been done and if anyone has seen the outcome to that you have to admit it makes you think maybe it wasn't such a great upgrade. In theory it should be a good upgrade but they make claims that just don't hold water. The filter is not a good filtering unit; I'll go as far as to say it's generally bad as far as filtering dirt. The plastic tube is just a piece of junk that may have been designed well but the quality of their manufacturing isn't worth the money to say the least. My first tube was not molded correctly and rubbed the hood liner really bad; they all do to some degree or another but this was because it was a bad mold. You could see how it was off. The replacement they sent had an issue with the ring that slips over the Intake; it was loose but it mounted so I ignored it. The other day I'm changing out the cap and rotor (Those of you with 5.2's or 5.9's know this is a pain to do)
I removed the tube to get a better angle on removing the cap; when I go to re-install the tube I see the ring is completely loose and part is out of the molding. So I try for the better part of an hour to get that band back up into it's place and it's impossible. It's like putting a square peg in a round hole! Since I have no other vehicle I have to make this work somehow; so I pull the band out and re-install it upside down. Sounds strange but it did work; although I'm sure it's not a tight seal. Truthfully it never really did seal completely in my mind anyways but now it's worse. Also there were a couple places where the band mounts inside the tube where plastic had obviously broken away; I can only guess that it's now in my intake somewhere? All this and what I paid? You would think you should expect more; charge me what you will but at least give me a quality product. It's my choice to spend the money or not.
So I contact a guy named Thomas Walden at K&N; this is the same guy that sent me the first replacement. I have tried and tried to get a hold of him and can't get a reply from him or customer service; when I call I get a voice mail or someone who will have him return my call. So basically I have nothing.
I will not own another K&N product; too expensive and it doesn't filter anywhere near like they claim it does. On top of that to add insult to injury their quality isn't there. I take care of what I have; I didn't throw it around the yard and blame them for my mistake. This is a quality issue they are very aware of. The first thing Thomas asked me when I called him about the first tube was if it was the band; he told me that they are having a lot of issues with it coming loose. Strangely my first one was locked in there tight.
If anyone is using this I would check it; even if you think it's ok. When the band comes loose from the plastic there will be plastic that will break off and go right into the intake.
I'm seriously thinking about going back to the original filter box; I really haven't seen any intakes that are worth the money they want for them. Plus I feel stupid paying $250-300 for one of these and truth be known it's probably not helping my engine as far as filtering anyways.
1) 2011 Grand Cherokee LImited
Blackberry Pearl
5.7L
Quadra Trac 2
Lux Group 2
20" tires and rims
Towing package
2) 2011 Grand Cherokee Laredo X
Blackberry Pearl
5.7L
Quadra Drive 2
Quadra Lift
Laredo X Group 25 package
Chrome Fogs and Mirrors
Off-Road Adventure II Package
P265/60R18 Michelin LTX M/S 2's
BWoody 4" Velocity Intake
10-17-2006, 07:54 AM
#2
Good post there, I sympathize with your situation. I was thinking of doing this upgrade and now I am concidering not doing it.
I have the "drop in" style K&N and it seems to be fine. while I dont have the sound thing I assume It still has an increase in flow over the paper style filters.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
— Joe Biden
10-17-2006, 08:00 AM
#3
The air flow isn't as much as they want you to think, plus no matter if it's a drop in or the kit the filter is the same media. (Cotton) The AEM Brute Force uses a different "Non oiled filter" but I just don't see it worth spending $300 for some marginal at best increase in HP. Honestly I think my MPG has gone down not up.
Blackberry Pearl
5.7L
Quadra Trac 2
Lux Group 2
20" tires and rims
Towing package
Blackberry Pearl
5.7L
Quadra Drive 2
Quadra Lift
10-17-2006, 08:07 AM
#4
I am not a fan of K&N products.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
10-17-2006, 09:32 AM
#5
BecauseRacecar
I bought a used FIPK and it has been fine. I did not buy it for MORE POWER becuase I knew that I would not see a power increase at all. I bought it second hand so it was not a big hit in the wallet but I really got it to free up room in the engine bay so I can relocate the washer fluid bottle. But so far no complatnts...
2013 FR-S
10-17-2006, 09:36 AM
#6
Mr. Hyde!
The ZJ V8's seem to have chronic problems with them - haven't heard of quality issues from their other setups. Mine has been good and necessary for room in the engine bay.
10-17-2006, 10:07 AM
#7
Hey i bought a volant air intake for my 4.7 and they dont give much power but it does make it sound much better but i got mine from AutoAnything.com and i payed some thing like $250 and it does make it feel more"peppy" IMO but not much power though
Matthew
Matthew
1999 4.7 Grand Cherokee
IRO 4" lift,JKS quick discos,DT 8000's,Baja MTZ 32x10.5x16,Cragar 8's,Flowmaster 40
2006 5.7 Grand Cherokee
2003 4.0 Wrangler
4" Pro-comp lift,33x12.50x15 Pro-Comp MT,Warn bumper,American racing AR-172,Piaa fogs
10-17-2006, 11:13 AM
#8
2000 Laredo V8
Ditch that stuff & get a TORNADO!!!! (JK)
2000 Laredo 4.7L Selec-Trac. 161K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 2X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X),
new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
10-17-2006, 01:48 PM
#9
Junior Member
the kn fipk works fine on mine. Im not saying it gives extra power, but it looks good, frees up room, and has never had a problem with fitment. Mine slides right over perfect, and seals up tight.
10-17-2006, 02:18 PM
#10
Have the drop-in K&N filter, maintenance instructions specify washing the filter in K&N filter cleaning solution. Is there an alternative to this, an off the shelf cleaner or solvent, that works just as well?
Equal Oportunity Jeep Owner
85 CJ-7
86 Grand Wagoneer
94 Cherokee
04 G-Cherokee
10-17-2006, 02:43 PM
#11
Jeep Jedi Master
My turbo city dual air intake works like a champ.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
10-17-2006, 03:28 PM
#12
A common mistake is people think its actually going to give you power, and more then that, power your going to feel. Not true, for the most part its just a sound, but its a cool sound. It does give you SOME power, but you won't feel it, I think its about 13hp max I'v seen advertised from non honda lovers/realists. So 13 horsepower over 235 dollars (going price on ebay) is about 18 dollars per 1hp. Now lets say you pay 4500 for a supercharger that adds 110hp, your now spending 41 dollars per hp.
But you would feel the S/C and love it
Moral of the story. Its actually much more finanicial feasible, plus it looks and sounds great, and you never need to buy another filter. I'm sick of people complaining. Research for yourself, if your going to let other people decide how you live your life, spend your money, and when to take a s*** then you deserved to be screwed. (even when your getting the best bang for the buck)
[url=http://www.mazdaworld.net/forums/index.php?showtopic=19]"Within the mind lies the greatest of all evils...Eternity" - Enigma02S[/url]
[url=http://www.cardomain.com/ride/2370949]2000 Millenia S...Five figure spending account[/url]
[url=http://www.cardomain.com/ride/2384051]1998 Jeep Grand Cherokee...Gone but never forgotton[/url]
[url=http://www.cardomain.com/ride/2383985]2003 BMW M3 SMG...For Sale, PM if interested[/url]
[url=http://www.cardomain.com/ride/2484240]2000 "Jeep Grand Cherokee...4.7, Quadra-Drive, Loaded.[/url]
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin - [url]http://www.mazdaworld.net[/url]
10-17-2006, 04:02 PM
#13
Exactly what I was thinking. I did the FIPK upgrade and complete exhaust with headers all at the same time. I felt the extra power. It maybe isn't a bunch, but i can tell it is there. If you watch any of the car shows on TV the #1 thing to do for extra power is upgrade your intake and exhaust because it has the best hp to money ratio.
97 ZJ 4.0
Current mods:
K&N Intake, Thorley header, Magna flow cat, Flowmaster muffler.
10-17-2006, 04:04 PM
#14
Its also more of a beginnier mod,once the car has the ability to breath better at its foremost entry and exit point, you can start to work on everything in between.
