Done got the 242 TC swap!!And it is rite - JeepForum.com
post #1 of 11 Old 12-09-2005, 04:41 PM Thread Starter
dapainter
When you change the 249 input shaft or TC case half remember to set the gears so they can work. I just put the stuff together and didn't realize that the berring thrust might be wrong now. Anyway I just reused the original TC case from the 242 with the new input shaft from the 249 and that put the shifting dogs back in it's proper location. Thanks Tim and wow I got it done without going into a shop with a box of wise guy type crap!
dapainter is offline
post #2 of 11 Old 12-09-2005, 04:48 PM
ZJPunk98
Which TC is a better case? 242 or 249?
erik
98' ZJ Limited 5.2
ZJPunk98 is offline
post #3 of 11 Old 12-09-2005, 05:07 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
242
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 11 Old 12-09-2005, 05:46 PM
ZJPunk98
what is the difference between the two? i have only 4hi and 4lo which one do i have?
erik
ZJPunk98 is offline
post #5 of 11 Old 12-09-2005, 09:20 PM
FLAWLESS
4hi -n-4lo = 249
2wd-4hi-4ft-n-4lo = 242
2wd-4hi-n-4lo = 231
FLAWLESS is offline
post #6 of 11 Old 12-10-2005, 08:38 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
The NP 249 is a decent case but it uses a Vicsous Coupler (VC) to transmit power to the front tires. The VC will last anywhere from 60K miles to 150K. It costs about $1000 to replace the VC.
The NP 242 is just as strong, but uses a belt instead of a VC and with the exception of taking awhile to disengage, usually doesn't have many problems. These can also be rebuilt for less than $400.
99+ GC's use a NP247 instead of the 249, and it actually circulates the fluid within the coupler, so they call it a Progressive Coupler or PC. I haven't seen a thread on one of those dying yet.
You could swap to a 247, but the speedometer setup between a ZJ and a WJ are not the same and it would be a pain to convert a ZJ to work with a WJ setup.
Hope this provided a little more info.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #7 of 11 Old 12-10-2005, 09:54 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
dapainter, that is GREAT news
A big highfive and to you!
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #8 of 11 Old 12-10-2005, 10:52 AM
ZJPunk98
how difficult would it be for me to obtain a 242 and install it, replacing my 249? If i could... would i have to change the shift selector in the cab, to indicate all the positions available?
erik
ZJPunk98 is offline
post #9 of 11 Old 12-10-2005, 01:24 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
You've done some nice work since you've been on here!
Kudo's!!!!!!!!!!!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #10 of 11 Old 12-10-2005, 02:09 PM
Death-Mobile
Death-Mobile's Avatar
242 is an excellent transfer case...woah...wait a second... THAT's RIGHT! I have a 242 and I love it!
Death-Mobile is offline
post #11 of 11 Old 12-10-2005, 02:31 PM
driabyor
driabyor's Avatar
1994 ZJ
try car-parts.com
it's a salvage yard site
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
doing 247/242 swap....need advice on front output shaft swap.. krazyteggy ZJ Grand Cherokee Forum 5 12-30-2009 06:44 PM
Detroit Locker vs. Lock-rite StrokedWJ ZJ Grand Cherokee Forum 11 01-15-2009 07:32 PM
Troubleshooting clunky lock rite StrokedWJ ZJ Grand Cherokee Forum 0 07-07-2008 08:25 PM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 05:28 PM
No-Slip and Lock Rite KillerZJ ZJ Grand Cherokee Forum 1 03-10-2003 06:51 PM
