Dome lights stay on with key off - JeepForum.com
post #1 of 21 Old 04-24-2013, 05:18 PM Thread Starter
Xpress
96 with 5.2. Dome lights are staying on when the ignition is off, turn right off whenever I turn the ignition on or to accessory. Already unplugged the door switches, as well as unplugged everything from the tailgate itself, the lights are still staying on.
Any ideas at all? I'm stumped here
All about that unibody life.
Xpress is offline
post #2 of 21 Old 04-24-2013, 05:22 PM
durango-bob
2006 WK
Do they turn off after a short while? Could be something wrong in the headlight switch.
durango-bob is online now
post #3 of 21 Old 04-24-2013, 05:40 PM Thread Starter
Xpress
They stay on all the time. Went to work and came back and they were still on. Tried messing with the headlight switch and got no change in results.
Xpress is offline
post #4 of 21 Old 04-24-2013, 05:50 PM
cwick13
check the door pin switches... my driver door pin switch in the front of door jam between hinges on the body.. wasn't being pushed in far enough... you can possibly throw a cpl pieces of electrical tape to build it up or you might have to replace it. but sounds like one is bad... if not is probably in the multifunction dash switch,
THANKS,
Cwick13
2 ZJ's, 2 XJ's, 1 cheromanche project half complete.. next a crew cab comanche i think.
cwick13 is offline
post #5 of 21 Old 04-24-2013, 05:54 PM Thread Starter
Xpress
Like I said I already unplugged the switches, still no change. I may have to unplug the dash switch next...
Though when I push the slider switch all the way up then back down, the relay in the passenger kick panel clicks and the lights flicker off for a heartbeat then are back on.
Xpress is offline
post #6 of 21 Old 04-24-2013, 06:36 PM Thread Starter
Xpress
Pulled the dash switch cluster out, no change, wound up just finding the relay (it was the only hot one) and popped it out. Not going to bother me, not keeping this one anyways, can still turn the lights on manually though.
I'd prefer to make my own harness for the transplant anyways, when it comes to lighting at least.
Xpress is offline
post #7 of 21 Old 04-24-2013, 08:33 PM
a70eliminator
Those light can be manually overridden on by simoly pushing in on the lense, you did check that they were in the off position right?
a70eliminator is offline
post #8 of 21 Old 04-24-2013, 11:02 PM Thread Starter
Xpress
Yes, that was the first thing I have checked, and no, they don't turn off when I do that.
Xpress is offline
post #9 of 21 Old 04-25-2013, 05:22 AM
cwick13
I still think door pins could work just fine but if not getting enough contact to close loop
THANKS,
Cwick13
cwick13 is offline
post #10 of 21 Old 04-25-2013, 06:55 AM
KoreaZJ
1994 ZJ
Relay contacts might be fused together. Swap out the relay.
KoreaZJ is offline
post #11 of 21 Old 04-25-2013, 08:04 AM Thread Starter
Xpress
I was always under the assumption that the circuit is completed from the door being opened (pin gets pushed out by spring).
Then why would the lights turn off when I turn the ignition on?
Xpress is offline
post #12 of 21 Old 04-25-2013, 08:17 AM
cwick13
They are pushed out by a spring.. But if they do not get pushed back in far enough to break contact (flip the switch...) they will never shut off with ignition or not.. Would be like riding around with open door.. If you don't have that problem.. It is Not in the pins
THANKS,
Cwick13
cwick13 is offline
post #13 of 21 Old 04-25-2013, 09:53 AM Thread Starter
Xpress
Definitely not the pins, like I stated. Unplugged them all and no change. Not the headlight switch assembly either, perhaps a short somewhere between the door switches and the relay panel...
Xpress is offline
post #14 of 21 Old 04-25-2013, 11:50 AM
KyleD31
When I amplified my door speakers, I cut the wires that I thought were for the speakers, then I had the same problem with the lights. The wires were in the passenger kick panel. When I reconnected them they were fine. Maybe something down there is messed up.
KyleD31 is offline
post #15 of 21 Old 04-25-2013, 01:48 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
push in the rear most lamp. it over rides everything but the ignition for turning the lights on.
it could also be a bad body control module.
ratmonkey is offline
