doing 247/242 swap....need advice on front output shaft swap.. - JeepForum.com
post #1 of 6 Old 12-30-2009, 06:13 PM Thread Starter
krazyteggy
So I am doing the 247-242 swap on my 00 Grand cherokee limited tomorrow and I have decided to leave my front output shaft as a "CV" joint style shaft. I know I have to swap the output shaft from the 247 to the 242 and I am fairly new to T-case swaps and would like to get it right the first time......has anyone ever come across a post on a tear down of the 242 or the actual swap of the output shafts?? Any help would be greatly appreciated. I have found threads floating around here on the t-case swap and I have all the necessary tools to do so....just unsure when I break open the cases......or do I even have to??? PLEASE HELP!!!!!!!
krazyteggy is offline
post #2 of 6 Old 12-30-2009, 06:21 PM
cmonson
Why are you swapping the output shafts??? Just find a 242HD out of a 99-04 with a V8 (assuming your LTD is a V8) and you will be in for a direct swap.
Remember to change the linkage location to the other hole though.
Also, search this board as it gets posted all of the time and most people that know the info won't bother posting b.c they get tired of the same questions over and over.
cmonson is offline
post #3 of 6 Old 12-30-2009, 06:24 PM Thread Starter
krazyteggy
I live in New brunswick and the price for DS around here are quite pricy, I paid almost 200CAD for the rear. and that was the cheapest I found.........however I would love to do the swap without having to take the cases apart if I could find a shaft for cheap......does the front DS have to be out of an 02-03 V8 as well??
post #4 of 6 Old 12-30-2009, 06:29 PM
cmonson
You can keep your existing front driveshaft & rear driveshaft.
just find a 242HD case out of ANY 99-04 grand cherokee with a V8. It will be a direct swap. No taking anything apart, no finding new driveshafts.
cmonson is offline
post #5 of 6 Old 12-30-2009, 06:37 PM Thread Starter
krazyteggy
I already found a donor Tcase(242HD) and DS out of a 02 which I was told I had to have that particular case(02-03 V-8 selec trac) for it to work and for my swap I would need the rear donor shaft because the 242 tcase will be 2 inches longer than the 247. and the donor shaft has the same spline count as well it is 2 inches shorter. I am going to check around a couple junkyards around here tomorrow for a front DS.......but I wonder if any other front DS would work or does it have to come from the same donor????
post #6 of 6 Old 12-30-2009, 06:44 PM
gbauer
You can probably re-use your old DS. swap the yokes and it should be fine. (I just swapped my yoke about 2 hours ago...)
Oh and the rear DS can be shortened. Ask a local auto-parts guy and they should be able to recommend someone. Mine was done for about $75.
gbauer is offline
249 to 242 swap: dealing with newer design long rear output shaft-- cut it? ammtview ZJ Grand Cherokee Forum 2 03-07-2009 05:45 PM
Driveshaft swap...output shaft seal plate? JC1390 ZJ Grand Cherokee Forum 6 10-20-2008 08:13 AM
Front drive shaft swap. Elkaholic ZJ Grand Cherokee Forum 7 05-04-2008 08:27 AM
WJ 247 -> 242 swap: Front Drive Shaft Q? LEDFoot ZJ Grand Cherokee Forum 4 12-05-2007 04:43 PM
Front drive shaft swap allan man ZJ Grand Cherokee Forum 6 03-07-2007 07:28 PM
