Dogde Alernator in ZJ, 4.0...??? - JeepForum.com
post #1 of 11 Old 05-25-2013, 02:39 AM Thread Starter
ShadowNDS
Hello @ all,
a friend told me that for some dodge the alternator with about 180 amps even with the 4.0 liter engines of the zj, 1996, should fit. In my unfortunately is only a 90 amp and I need more amps.
Do you have more info for me because what could it be? Eventually, the number of Mopar parts or even Nippon Denso and another manufacturer?
Thanks in advance
Sorry for my bad english...
Grand Cherokee 242cui I6, build in 1996 in Graz, 2" lift with spacers, 245/75 R16 BF Goodrich AT...
Sorry for my bad english, i donīt use it the last years...
ShadowNDS is offline
post #2 of 11 Old 05-25-2013, 07:26 AM
OverlandZJ
Part#56027913
This is the 136amp alternator which was OEM from the V8 Grand Cherokee's and Dodge Dakota/Ram's etc.
OverlandZJ is offline
post #3 of 11 Old 05-25-2013, 11:17 AM
Foundrydude
If your truck was optioned differently, it would have the 136 amp alternator. So your parts store should list the higher alternator without needing to look it up for a different vehicle.
Foundrydude is offline
post #4 of 11 Old 05-26-2013, 03:48 PM
technophat
Motor City Reman alt
I opted for the Motor City Reman 150amp alt for $250. It bolted in ok, but I had to create some small 12ga pieces of wire with two ring terminals, as it was not a 1 to 1 replacement. 30 min of work and an unexpected trip back to the store, but I'm happy with the outcome.
1997 ZJ Laredo, 4.0, 42re trans, 242 T-case
1994 ZJ Laredo, 4.0, 42re trans, NP231 T-case
technophat is offline
post #5 of 11 Old 05-27-2013, 03:35 AM Thread Starter
ShadowNDS
From the factory the car had installed the 136 amp alternator, as that was broken, I unfortunately have no other than the 90 amps.
Now I have a lot of electrics, a winch, and I need more amps.
As I said, a friend said that one should fit well for any Dodge with 180 amps. Just what is it and for what vehicle?
post #6 of 11 Old 06-03-2013, 02:57 PM
eagsc7
1994 ZJ
Ask your friend. Or goto O'rileys and ask them. They Should be able to search...
eagsc7 is offline
post #7 of 11 Old 06-03-2013, 07:44 PM
MaintMech
Old and in the way
MaintMech's Avatar
I'd be real surprised if they have an O'Rilies in Germany.....
Try searching the Forum, I know someone's swapped in a Dodge alt. for the Jeep!
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #8 of 11 Old 06-03-2013, 08:52 PM
kg6mov
Hears the voices
kg6mov's Avatar
The dodge dakota or durango use the 180 Amp alternator.
kg6mov is online now
post #9 of 11 Old 06-04-2013, 09:26 AM
KyBoy1991
I believe it's a 160 Amp alternator...not 180.
That being said, right after I did the swap of using a Dakota/Durango/Ram 160 amp alternator...another user here finds that there is a Chrysler Town & Country minivan alternator that is a DIRECT fit and there is no cutting/splicing of wires at all. Think they're about $125 at the Zone????
You could search thru any of the threads/post I've made on that subject and you'll find that link.
KyBoy1991 is offline
post #10 of 11 Old 06-04-2013, 09:38 AM
JAMS201075
JAMS201075 is offline
post #11 of 11 Old 06-04-2013, 09:42 AM
JAMS201075
