-   -   Dogde Alernator in ZJ, 4.0...??? (http://www.jeepforum.com/forum/f13/dogde-alernator-zj-4-0-a-1528008/)
ShadowNDS 05-25-2013 01:39 AM
Hello @ all,
a friend told me that for some dodge the alternator with about 180 amps even with the 4.0 liter engines of the zj, 1996, should fit. In my unfortunately is only a 90 amp and I need more amps.
Do you have more info for me because what could it be? Eventually, the number of Mopar parts or even Nippon Denso and another manufacturer?
Thanks in advance
Sorry for my bad english... :shhh:
OverlandZJ 05-25-2013 06:26 AM
Part#56027913
This is the 136amp alternator which was OEM from the V8 Grand Cherokee's and Dodge Dakota/Ram's etc.
Foundrydude 05-25-2013 10:17 AM
If your truck was optioned differently, it would have the 136 amp alternator. So your parts store should list the higher alternator without needing to look it up for a different vehicle.
technophat 05-26-2013 02:48 PM
Motor City Reman alt
I opted for the Motor City Reman 150amp alt for $250. It bolted in ok, but I had to create some small 12ga pieces of wire with two ring terminals, as it was not a 1 to 1 replacement. 30 min of work and an unexpected trip back to the store, but I'm happy with the outcome.
ShadowNDS 05-27-2013 02:35 AM
From the factory the car had installed the 136 amp alternator, as that was broken, I unfortunately have no other than the 90 amps.
Now I have a lot of electrics, a winch, and I need more amps.
As I said, a friend said that one should fit well for any Dodge with 180 amps. Just what is it and for what vehicle?
eagsc7 06-03-2013 01:57 PM
Ask your friend. Or goto O'rileys and ask them. They Should be able to search...
MaintMech 06-03-2013 06:44 PM
I'd be real surprised if they have an O'Rilies in Germany.....
Try searching the Forum, I know someone's swapped in a Dodge alt. for the Jeep!
kg6mov 06-03-2013 07:52 PM
The dodge dakota or durango use the 180 Amp alternator.
KyBoy1991 06-04-2013 08:26 AM
I believe it's a 160 Amp alternator...not 180.
That being said, right after I did the swap of using a Dakota/Durango/Ram 160 amp alternator...another user here finds that there is a Chrysler Town & Country minivan alternator that is a DIRECT fit and there is no cutting/splicing of wires at all. Think they're about $125 at the Zone????
You could search thru any of the threads/post I've made on that subject and you'll find that link.
JAMS201075 06-04-2013 08:38 AM
http://www.ebay.com/itm/Dodge-CARAVA...9623d6&vxp=mtr
This is a direct bolt on.
JAMS201075 06-04-2013 08:42 AM
http://www.ebay.com/itm/New-Alternat...ef8c85&vxp=mtr
or this.
The time now is 03:28 PM.
