Does PCM Need to be Programmed? - Page 2 - JeepForum.com
post #16 of 46 Old 08-10-2008, 03:05 PM
moparrr07
UPSELL just means they are trying to sell you something that was broken that you didnt come in for, brake light bulbs, leaks etc,
whichever tech gets the most upsells per month gets a bonus,
call the dealership not saying who you are and ask them how much it would be to prgram a pcm, then go get your own and have them program it for you( if it needs it)
-Black Limited 1998 Jeep ZJ 5.2 nv3550 np242, 35s, lots of other stuff
moparrr07 is offline
post #17 of 46 Old 08-10-2008, 03:22 PM Thread Starter
eparke
1991 XJ Cherokee
Originally Posted by muddyjgc View Post
I believe that is virtually impossible with fuel injection. The injectors would have to be stuck open for any fuel to get in the cylinders. The injectors are closed until you start cranking the engine. The pump is running for a few seconds to build the fuel pressure in the fuel rail. Then it shuts off until you start the engine.
I thought the same thing, that it is impossible for this to happen. But it is happening. Perhaps I have more than one thing going on here. Or the PCM is just so wacked out that it doesn't know what is going on?
eparke is offline
post #18 of 46 Old 08-10-2008, 03:25 PM Thread Starter
eparke
1991 XJ Cherokee
Ebay has the PCM's which says, "Programmed to your VIN". Is this reliable? Or will I still need to have it programmed at the dealer? Also, Checker has them and it says, "Flash Programmed at the factory". The PCM is strictly for the 1997 Grand Cherokee, so are they telling me that I won't need to take it to the dealer?
eparke is offline
post #19 of 46 Old 08-10-2008, 03:29 PM
moparrr07
hard to say, some do some dont, they can depend on theft stuff, there were changes middyear all the time
post #20 of 46 Old 08-10-2008, 06:28 PM Thread Starter
eparke
1991 XJ Cherokee
New CPS
Okay, I put in a new CPS. No change. Now, I am to the point of changing out the PCM. But since I have changed mine out with a used one, and it did the same thing...I am nervous that a new will either not fix the problem or my system might fry the new one. I wish I had another ZJ here to try this PCM in it to see if it would work with the other jeep.
Does anyone out there have the capability to test my PCM if I send it to you? Thanks.
eparke is offline
post #21 of 46 Old 08-10-2008, 06:57 PM Thread Starter
eparke
1991 XJ Cherokee
One other thing
One other thing...There are places on the forum where people talk about grounding out a wire to shut down the Vehicle Theft Security System. They say to ground out a wire in the drivers door that is purple with a yellow tracer. My Jeep does not have this wire. My door has a purple wire with a BLACK tracer. Is this the wire that I need to ground out to see if shutting down my alarm might get this thing started? None of my wiring diagrams show anything to do with the alarm system.
eparke is offline
post #22 of 46 Old 08-11-2008, 06:00 AM
Kolak
Vendor
Kolak's Avatar
The unusual symptoms with the fuel gauge and the security system would lead me to believe the body control module is somehow involved with this.
Kolak is online now
post #23 of 46 Old 08-11-2008, 07:36 PM Thread Starter
eparke
1991 XJ Cherokee
Kolak, thanks for the tip. I actually located online an excellent repair manual today - I think it may actually be the Jeep Technician Repair Manual, and I will look into the BCM. After reading a bit in the manual, I think you may be right. I will update with what I find. Thanks again.
eparke is offline
post #24 of 46 Old 08-18-2008, 11:40 PM Thread Starter
eparke
1991 XJ Cherokee
Well, after going through all the pinouts in the BCM, I am no further ahead. All of the grounds and power are fine with the BCM. I feel like towing this jeep to the lake and letting it roll down the boat ramp. Why would the red led on top of the dash come on solid about 30 seconds after the keyswitch is turned on?
eparke is offline
post #25 of 46 Old 08-19-2008, 06:46 AM
Kolak
Vendor
Kolak's Avatar
But what about the BCM itself? That behavior sure sounds like it's throwing fits.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is online now
post #26 of 46 Old 08-20-2008, 06:17 PM Thread Starter
eparke
1991 XJ Cherokee
Well, I have located a guy who has the exact same jeep that I have. He is parting it out but still has the motor running and said that it would be okay if I brought my BCM over and put it in his jeep to see if it acts the same way my jeep does. If his jeep still starts with my BCM, I'll put my PCM in and see what happens. This will tell all. I'm doing this Friday morning and I'll post the results Friday evening.
eparke is offline
post #27 of 46 Old 08-22-2008, 05:55 PM Thread Starter
eparke
1991 XJ Cherokee
Well, this was a no-go. He told me his was a '97 but when I got there it looked more like a 1995 or before. The PCM and BCM were totally different. Oh well. Then I found a BCM and a PCM (two different wrecking yards) and purchased them. Still no spark. With the new BCM though, the red led does not come on anymore, and when I lock the doors with the fob, the horn chirps, (even with the purple/yellow wire grounded) which it did not do before when the jeep was running .
I am totaly lost here. Never felt so helpless in my life.
eparke is offline
post #28 of 46 Old 08-23-2008, 01:52 PM Thread Starter
eparke
1991 XJ Cherokee
Is this a telltale sign that it is an alarm problem?
Okay, I am finding out that if my problem is an alarm problem, then the jeep would start for a few seconds and then shut down. Is this correct? I don't get any spark from the get go, so does that tell me that the problem is NOT the alarm? I don't have the lights flashing and all the other stuff that people have when their alarms are giving them trouble. Have I been barking up the wrong tree?
eparke is offline
post #29 of 46 Old 08-23-2008, 01:59 PM
F4D
Have you checked the coil?
F4D is offline
post #30 of 46 Old 08-23-2008, 02:16 PM
Luckyduck
I feel for you. I am having trouble in my TJ with my PCM. I have 4 sitting in my jeep right now My kill switch (I also got that little red light on the dash) stopped working then started again today. Sorry I don't have any advice besides if the dumping it in the river works let me know so I can do the same
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
Do ECM's from Autozone need to be Flashed/Programmed? jeepsgonewild ZJ Grand Cherokee Forum 4 12-14-2009 05:29 PM
Does a ECM for a 94 Grand Cherokee need to be programmed with my vin# Ved ZJ Grand Cherokee Forum 6 10-14-2009 08:40 AM
New PCM need to be programmed for 96' bgky ZJ Grand Cherokee Forum 1 10-07-2009 05:21 PM
Previous owner programmed computer????? jeepguy98 ZJ Grand Cherokee Forum 15 08-28-2009 05:56 PM
