Does anyone know if its possible for this swap - JeepForum.com
post #1 of 17 Old 04-30-2013, 12:41 AM Thread Starter
Fresh_prince101
Can i use a pcm from the 96-98 zj on a 93zj
Fresh_prince101 is offline
post #2 of 17 Old 04-30-2013, 01:47 AM
kensnelling
No, the JTEC is a total different design.
Ken
kensnelling is offline
post #3 of 17 Old 04-30-2013, 02:18 AM Thread Starter
Fresh_prince101
Thanks. An do you think by me changing the pcm it would also fix my voltage problem also because my zj runs on low volts.
post #4 of 17 Old 04-30-2013, 02:19 AM Thread Starter
Fresh_prince101
I have had the alternator tested it came back good
post #5 of 17 Old 04-30-2013, 02:52 AM
kensnelling
It might correct the problem. Other possible problems could be corroded battery cables, dirty grounds, weak battery, etc. First step is to do a vehicle charging system check, and a battery load test. The PCM's internal voltage regulator is not the usual cause of a charging system problem.
I've seen the test machines at the auto parts stores for off the vehicle alternators and starters pass defective units and fail good units.
Ken
post #6 of 17 Old 04-30-2013, 01:14 PM Thread Starter
Fresh_prince101
Ok so im hearing that there is a specific pcm i have to find if i went to a junk yard to get one. How do i know what's right or not?
post #7 of 17 Old 04-30-2013, 01:42 PM Thread Starter
Fresh_prince101
i heard i have to have a certain pcm for my 93 zj
How do i know what pcm is right for my truck an whats not
post #8 of 17 Old 04-30-2013, 02:05 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
match the part numbers on the pcm. or find a zj with the exact same options and trim level as yours.
ratmonkey is offline
post #9 of 17 Old 04-30-2013, 02:15 PM Thread Starter
Fresh_prince101
Does it matter about the year of the zj
post #10 of 17 Old 04-30-2013, 03:32 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
yes
post #11 of 17 Old 04-30-2013, 03:45 PM Thread Starter
Fresh_prince101
So what years should be right
post #12 of 17 Old 04-30-2013, 03:47 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
93.
94-95 are slightly different.
96-98 are completely different.
engine type and factory security equipment matter.
post #13 of 17 Old 04-30-2013, 04:19 PM Thread Starter
Fresh_prince101
Could i use the 94-95
post #14 of 17 Old 04-30-2013, 08:55 PM
kensnelling
No, you'll need the same year that you have, in this case a 1993. As ratmonkey already explained, if you're getting one from the auto salvage you'll need to find one with the same part number as is on the label on yours. You need one with the same engine as you have, and whether or not your ZJ and the donor ZJ have security is very important. You can't mix those.
Ken
post #15 of 17 Old 05-02-2013, 12:16 PM Thread Starter
Fresh_prince101
Ok should be my last question does the number have to be exactly the same cause i found some ata junk yard just the last 3 numbers are different
