does a '98 5.9 have an Airbag Shut Off Switch? - JeepForum.com
post #1 of 10 Old 07-28-2011, 03:24 AM Thread Starter
Iceman_RNR
Hello,
after searching a little on the forums and the web I haven't found an answer to the question about whether or not a 1998 5.9L Grand Cherokee has an Airbug Shut Off Switch?
On my 2000 TJ it's got a separate key hole to turn it off on the center console, but I haven't been able to find that on the GC.
The owner's manual says to check the paragraph on Passenger Side Shut Off Switch, but it doesn't have such a paragraph in the manual?
Any and all info is welcome,
Ron
'84 CJ7, '96 CTD, '00 TJ
Iceman_RNR is offline
post #2 of 10 Old 07-28-2011, 10:11 AM
muddyjgc
2005 WK
Air bag shut of switches are only available on vehicles with no or back seats too small for a baby car seat. Standard and extended cab pickups have them but not full crew cabs. I would imagine the TJ rear seat would fall under the "too small" back seat category. The ZJ doesn't qualify.
I think they have done away with the switches over the past couple of years. Now they use weight sensors in the seat and whether or not the seat belt is buckled to determine if the airbag is on or off.
muddyjgc is offline
post #3 of 10 Old 07-28-2011, 11:01 AM
Candymancan
isnt there a fuse for the airbag ?
Candymancan is offline
post #4 of 10 Old 07-28-2011, 11:49 AM
ZJ5point2GCL
there isn't but if you have to disable it for some reason, both air bags have yellow clips near the obd II port that you can disconnect.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #5 of 10 Old 07-28-2011, 01:17 PM
MeanGreenZJ
MeanGreenZJ is offline
post #6 of 10 Old 07-28-2011, 03:19 PM Thread Starter
Iceman_RNR
thanks for the info. So it doesn't come with it standard, like in my 2000 TJ. You have to jump through lawyer's hoops to be able to install an on-off switch for the passenger side airbag ...
post #7 of 10 Old 07-28-2011, 04:01 PM
MeanGreenZJ
Sounds that way. Seems that your 2000 TJ didn't come with it standard since it's on the list as well. My guess is that someone before you bought it jumped through lawyer's hoops.
post #8 of 10 Old 07-28-2011, 09:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
my g/f's 2000 tj came with the switch stock.
ratmonkey is offline
post #9 of 10 Old 07-28-2011, 10:39 PM
squazz
Not to side track but tgis thread reminds me that I unhooked both front sensors in my 93 when I din my bumper cutting and my airbag light never came on am I in danger of this thing exploding at any givin moment? How would I totally disable it? A plug along the steering colum?
squazz is offline
post #10 of 10 Old 07-29-2011, 04:56 AM Thread Starter
Iceman_RNR
my 2000 TJ also came with it stock (late '99 model), but for the GC you'd have to go through the process to have the ability to turn the passenger side airbag off ...
brake light switch/stop lamp switch tirus89 ZJ Grand Cherokee Forum 3 10-26-2011 03:53 PM
02 Grand Cherokee quit as if I shut off switch gomopargo ZJ Grand Cherokee Forum 12 02-25-2009 06:54 PM
VIC Won't Shut Off _Kyle_ ZJ Grand Cherokee Forum 4 11-11-2008 02:38 PM
heater control/light switch/rear wiper switch Lights Dillonzj ZJ Grand Cherokee Forum 3 10-10-2008 10:06 PM
2002 GC Airbag shut-off switch? gymsbyjo ZJ Grand Cherokee Forum 10 10-02-2006 09:12 PM
