Dodge Neon Injectors in the 4.0 - JeepForum.com
post #1 of 240 Old 12-25-2010, 11:29 PM Thread Starter
harwood909
Just read over on the cherokee forum that guys are putting dodge 2.0 and 2.4 neon injectors in the 4.0. The theory behind it is the stock jeep injectors only have one or two holes to shoot gas... the neon's have four holes.
Question: Will it work on the ZJ?
Custom Machined Budget Boost
Literally Built
harwood909 is offline
post #2 of 240 Old 12-26-2010, 01:20 AM
melk
Try it and find out?
Main concern would be to see if they operate at a similar pressure.
melk is offline
post #3 of 240 Old 12-26-2010, 06:07 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
ford motorsports injectors or the accel ones meant for ford 5.0's are 4 hole ev1 injectors.
ratmonkey is offline
post #4 of 240 Old 12-26-2010, 09:04 AM
tonymartin
Speaking of injectors, one of mine is dodgy according to an OBDII scan, I got code P0207 Injector Circuit/Open cylinder 7 so would I be able to pull one from any jeep from the scrap yard or only a V8? If that fixes it I may save tyo get the fords after the holidays!
What lb's per hour should I look for as a minimum swap output?
93 Renegade|Home made add a leaf (by PO, changing out soon)|Rancho adjustable shocks|31x15 BFG AT's|15" GT alloys|AFE Headers|Red SpiderWebShade Trail Cage|Free Sense of Adventure
tonymartin is offline
post #5 of 240 Old 12-26-2010, 11:52 AM
ZJ5point2GCL
never heard of the neon ones, but the fords from the 4.6 or 5.0 are good, i have some in my 5.2 and they are great, more throttle response and a bit more MPG's, smoother idle and quieter exhaust note.
the factory ones have 1 hole the ford ones have 4
and it will work in your 4.0
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #6 of 240 Old 12-26-2010, 09:53 PM
CatSplat
1994 ZJ
It's a fairly common swap over in Australia for the XJ 4.0s, and since they're identical to the ZJ 4.0s they should work just fine. The 2.4L injectors are 4-pintle EV6 designs, so they work more efficiently than the EV1 units - or so they say! I have a full set of the 2.4L injectors ready to swap in, but I'm going to create a mileage baseline with a freshly-rebuilt set of Bosch 19# EV1 injectors first to see if there's any noticeable mileage or power gains. I'm doing that on a 5.9 though, so it may not be totally relevant to the 4.0s. Really, for the price of 6 junkyard injectors, I'd say it's worth it just for you to try out.
Make sure you grab ones with the right electrical connector, all the ones I saw used the same connector as the stock ZJ Deka injectors but newer ones may have the newer (USCAR?) plug.
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #7 of 240 Old 12-26-2010, 10:13 PM Thread Starter
harwood909
Thats was my thoughts on it. 20 bucks from the local u-pick and hey preto...
Literally Built
post #8 of 240 Old 12-26-2010, 10:17 PM
ZJ5point2GCL
so what does work more efficiently mean? like better fuel atomization? or whats the benefit of the EV1 over the EV6? is it worth getting adapters?
post #9 of 240 Old 12-26-2010, 11:28 PM Thread Starter
harwood909
Originally Posted by zj5point2gcl View Post
so what does work more efficiently mean? Like better fuel atomization?
bingo
Literally Built
post #10 of 240 Old 12-26-2010, 11:43 PM
ZJ5point2GCL
but you still need to splice your injector harness or get adapters right?
post #11 of 240 Old 12-27-2010, 12:11 AM
94chb
nope most have the same style plug, i gave some of my 4.0 injectors to my buddy for his 2.9 ford ranger they were the same
94chb is offline
post #12 of 240 Old 12-27-2010, 12:44 AM
CatSplat
1994 ZJ
Nope! All the 2.4L injectors I pulled had the same connector as the stock ZJ injectors, direct swap.
As for your other questions, the EV6 has better atomization which leads to a more complete burn, which increases the efficiency of the engine. You should, in theory, see an increase in power and mileage over the stock (junk) Deka injectors. How much of an increase, I can't say. EV6 injectors are more reliable and less likely to leak than EV1, and and work correctly over a larger range of fuel pressures.
The Jeep of Theseus
CatSplat is offline
post #13 of 240 Old 12-27-2010, 05:04 AM
melk
Another thing to add to my JY list
Any general idea of what years have the EV6? Do they have any markings or numbers to tell I'm pulling the right kind?
melk is offline
post #14 of 240 Old 12-27-2010, 06:47 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
ev6 is a connector style, i don't see how you can plug it into an ev1 pigtail.
post #15 of 240 Old 12-27-2010, 09:27 AM
CatSplat
1994 ZJ
That's actually a common misconception, EV1, EV6, EV12, etc are injector body designs, the connector is separate from that and selected by the OEM. The older connector design was present on the vast majority of EV1 injectors and many EV6 injectors as they were phased in. This connector, due to being present on basically all EV1 injectors is known to most people as the "EV1" connector, however its real name is the Jetronic/Minitimer connector. Most early EV6 injectors had the Jetronic/Minitimer as well, mostly so the car companies could upgrade to better injectors without having to redesign wiring harnesses. Later, the OEMs moved to a new connector design, called USCAR. This connector became associated with the EV6 body design and most people assume that all EV6 injectors came with this connector.
EV1, Jetronic/Minitimer connector:
EV6, Jetronic/Minitimer connector:
EV6, USCAR connector:
Also, the Jetronic/Minitimer is still specced by some manufacturers. The top injector in this picture is a late EV12 design with the J/M plug.
The Jeep of Theseus
CatSplat is offline
fuel injector
new injectors... Travis873o ZJ Grand Cherokee Forum 1 08-24-2010 09:15 PM
what size injectors are stock for 94ZJ? Are '94'95 injectors the only ones i can use hvywt77 ZJ Grand Cherokee Forum 9 09-23-2009 10:18 AM
Injectors RFisher ZJ Grand Cherokee Forum 5 03-19-2007 03:27 PM
i need injectors veso_Ht ZJ Grand Cherokee Forum 6 03-03-2007 07:55 PM
Injectors turk ZJ Grand Cherokee Forum 2 07-20-2004 11:27 AM
