dodge durango steering box upgrade - JeepForum.com
post #1 of 51 Old 01-19-2010, 06:53 PM Thread Starter
bigbluezj94
1994 ZJ
i cracked my steering box last weekend at logandale and it moves around horribly now. i plan on plating the frame and getting a durango steering box along with hydro assist. they say that it is a heavier duty box and it has 4 mounting holes vice the 3 of a stock grand. but does it have the same spline count pitman arm??
edit: also, if i buy a remaned one from autozone or whatever, will they take my grand one as a core or will they try and give me a hassle??
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
BigBlue build 3/4 ton axles, LAs, 37s
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline
post #2 of 51 Old 01-19-2010, 08:48 PM
amonostereo
I was literally JUST going to ask this exact same question! (great minds, you know.)
That is kinda weird actually.....
BUT (more Q's):
I heard that the Durango box (at least that of a 99 V8) has just 3 holes. Correct?
I do not have hydro assist in my stock POS. Is it possible to install?
Is the swap more difficult in any way than just trading it out for a new (ZJ) Steering Gear?
'93 5.2L V8, Laredo, 242 TC swapped from a 249, 3" Coils up front and Front coils in the Rear, JKS Adjustable Track bar, K&N Cold Air Intake with Amsoil filter, Rear cargo area shelving, and KOR's Steering Gear Brace, IRO's Over-The-Knuckle Steering, Top Light Rail, Top Tire Carrier... for now...
OR If you prefer acronyms: 93 5.2 V8, 249>242, 3" FC, ~2" RC, JKS Adj. TB w/ KOR TB Bracket, K&N CIA w/ Amsoil filter, Shelves, KOR SB, IRO OTK HD steering
amonostereo is offline
post #3 of 51 Old 01-19-2010, 10:29 PM
amonostereo
After research on many sites, I have repeatedly found that a '99 V8 Dodge Durango steering gear box will directly swap in. There should be no spline difference issues.
Also, a 1980+ Wagoneer will fit, and is a beefier box, but there seems to be dissent about the usefulness of this: it is time that wears down the gear boxes, so getting an older gear box may not improve any play experienced previously.
I still am unsure about hydro-assist. (did you mean that you already have it and you want to get a steering gear which is compatible?)
Knowing the typical 'diligence' of my local Autozone/Checker folks, I would be willing to be that you could throw an alternator in the box and they wouldn't know the difference, much less a steering gear ever so slightly different from what they are expecting. On the other hand, it would probably mess up their re-manufacturer's assembly line.
Bottom line: I am doing it. Pulling the gear box this Friday. I will let you guys know how it works out. Wish me luck!
post #4 of 51 Old 01-19-2010, 10:56 PM
Virmagicus
Virmagicus's Avatar
Yep, splines are the same.
Jeff
Virmagicus is offline
post #5 of 51 Old 01-20-2010, 10:30 AM
amonostereo
To those who have done this mod:
Was it easy?
Do you have 3 or 4 mounting holes?
Would you recommend hitting up the junkyard or Autozone/Checker/NAPA?
Thanks a bunch guys!
post #6 of 51 Old 01-20-2010, 11:22 AM
LordHobbit
This is awesome. Pics, writeup or other please.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #7 of 51 Old 01-20-2010, 12:53 PM Thread Starter
bigbluezj94
1994 ZJ
car-part.com has a bunch and they are as low as 35 bux, but you never know the shape of those. i think im going to go the autozone route...
as for the hydro assist, i know a stock box with work but ive heard that a durango gear is better and it alone will have any easier time turning my 37s. so im going to drill and tap it for hydro assist. ill make a write-up if in anyone is interested. i will also be plating my frame with to ensure no cracking/bending/breaking there.
post #8 of 51 Old 01-20-2010, 04:09 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
I wouldnt put a used box in my jeep, but if you're on a budget and dont mind possibly doing it a couple times until you get a decent box, then the JY route may be for you.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #9 of 51 Old 01-20-2010, 04:38 PM
shdybrady19
where exactly do you drill and tap for hydro assist?
1996 5.2 orvis: 6" lift, 33x12.50's, 8.8 rear, t-case skid, gas tank skid, 242
Originally Posted by nick62087 View Post
If you can weld and aren't afraid to take a chance, I'd say try it - someone's gotta do it.
LOOKING FOR 96-98 ZJ CARPET, TAN OR BLACK IN COLOR, ALSO LOOKING FOR HOOD HINGES. 93-95 MIGHT BE COMPATIBLE
shdybrady19 is offline
post #10 of 51 Old 01-20-2010, 05:44 PM
Eshindi
Originally Posted by Eshindi View Post
You have to tap another hole where the pressure line is on the pump. I have seen people split the line ( i wont do that).
Here is a writeup on how to do a full hydro steering.
Full hydro and hydro assist are very similar except that with full hydro you just basically remove the gear box, steering column and they give you a strong pump.
'15 JK Stock | 4k Miles | Bone Stock
SOLD '99 WJ I6 | Claytons LA | 6.5" | HP D44 | F9" | 35's
Eshindi is offline
post #11 of 51 Old 01-20-2010, 05:46 PM
Eshindi
Delete me opps
Eshindi is offline
post #12 of 51 Old 01-20-2010, 07:21 PM
sandman
Was it easy?
i dont know what years have the 4 mounting holes but this is the main reason for the upgrade since the weakness to our set up is the 3 hole design.
Junk yard is probably going to be your best bet.
1993 Jeep ZJ. 4.0
sandman is offline
post #13 of 51 Old 01-20-2010, 07:29 PM
sandman
done on an XJ but its the same. Cheap Hydro Assist - Virtual Jeep Club
when you tap the box you gotta be sure you get all the shavings out.
1993 Jeep ZJ. 4.0
sandman is offline
post #14 of 51 Old 01-20-2010, 07:45 PM
SnowLeopard
I had to replace my steering box earlier this year, and I didn't know about this option back then. Autozone does have good deals on rebuilt units with a warranty on them. They honor it, too. They're good quality rebuilds. I bought the KOR steering brace to reinforce it afterward, but I think the Durango box would negate needing this. It sounds like a superior option if you can manage.
SnowLeopard is offline
post #15 of 51 Old 01-21-2010, 09:07 PM
Virmagicus
Virmagicus's Avatar
Only if the rails are reinforced to help keep the box from flexing. The rails are the weak point. If you plan on running bigger tires along with moderate wheeling, it would be a good idea to do both.
Jeff
Durango Steering Box Writeup gunthagunth ZJ Grand Cherokee Forum 28 05-01-2014 09:16 AM
Will a 06 Dodge Durango 4.7 fit in a 00 WJ hillside250 ZJ Grand Cherokee Forum 6 04-10-2009 02:38 AM
Durango steering box not going as planned mopar3389 ZJ Grand Cherokee Forum 3 07-29-2008 10:39 AM
Durango steering box or stock ZJ replacement? ZJ Limited ZJ Grand Cherokee Forum 12 08-29-2006 03:20 PM
Dodge Ram/Durango 4wheel drive compared to WJ? bkeast17 WJ Grand Cherokee Forum 5 05-17-2004 02:04 PM
