Dodge dakota/truck parts? - JeepForum.com
post #1 of 9 Old 04-12-2013, 08:40 PM Thread Starter
ThatONeJeePeR
1991 XJ Cherokee
Will an oil pan off a 5.2/5.9l dodge Dakota/truck fit my 5.2? Have you ever used Rtv for an oil pan gasket? And finally will the tow hooks work? TIA
Originally Posted by misterpookie View Post
*sigh* using a controller for an FPS is like trying to jump start your car with nipple clamps: simply not the right tool for the job.
ThatONeJeePeR is offline
post #2 of 9 Old 04-12-2013, 10:22 PM
kensnelling
About the oil pan, I honesty don't remember. Have a salvage yard check their Hollander manual, that will tell for sure.
As for the RTV in lieu of the gasket, in short, no, dont do it. The RTV will seal the side rails of the pan, but the gap on the front and rear is too large, the RTV will blow out.
And the tow hooks will need a bracket/thick steel reinforcement to attach to the frame stub. If hooked directly to the sheet metal frame they'll pull through first time you use them.
Ken
kensnelling is offline
post #3 of 9 Old 04-13-2013, 01:16 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
no
no
and no.
ratmonkey is offline
post #4 of 9 Old 04-15-2013, 04:17 PM
95WhiteTrash
i would think that the oil pan would fit seeing as you can swap in a 5.2 or 5.9 engine out of a dakota\durango without having to change the oil pan.
correct me if i am wrong but the magnum 5.2 is a magnum 5.2 regardless of what vehicle it is put in!
95WhiteTrash is offline
post #5 of 9 Old 04-15-2013, 04:24 PM
95WhiteTrash
the problem the OP is having is that he "bottomed out/hit something" that crushed the oil pan right where the drain plug is and he cannot remove the drain plug now! anybody have any ideas on how to get a stuck drain plug out of a slightly crushed oil pan? we have tried a socket / box end wrench, ended up striping the plug, put some vice-grips on it as tight as humanly possible and tapped on them with a hammer to no avail! that plug isn't moving!
if we removed the pan and straightened out the dent from the inside do you think we would be able to get that plug out then?
any and all help is greatly appreciated!
post #6 of 9 Old 04-15-2013, 05:57 PM
Foundrydude
Even though I don't trust oil change places....if the truck's a beater and the pan isn't leaking......
All future oil changes would be thru the dipstick tube at an oil change place. It'd live with the dent forever.
Whatever you do, don't fix the pan and reinstall. If it comes off, put a different one back on that was never damaged.
good luck
Foundrydude is offline
post #7 of 9 Old 04-15-2013, 06:01 PM
dnuccio
IIRC some of them were front sump, our jeeps need rear sump. but i could be wrong
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #8 of 9 Old 04-15-2013, 10:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The pans are notched differently for starter and exhaust clearance.
There's also a mid sump version.
post #9 of 9 Old 05-10-2013, 10:10 PM
sharphintofemo
NO. Made this mistake. Had to replace my engine and the salvaged engine came from a durango. Oil pan is different, oil sending unit had to be switched and the oil dipstick/tube also should be switched. Got the engine in and realized my mistake! Much easier to do when the engine is out. You won't be able to put the starter in, won't be able to connect the exhaust and the hood will snap the handle off of the dipstick.
R.I.P. 1995 XJ. I'll miss my 5 spd.
98 ZJ 5.2
sharphintofemo is offline
