Do I need a Transmission? - JeepForum.com
post #1 of 26 Old 12-25-2012, 09:36 PM Thread Starter
MadMattster
I have a 1993 GC, 4.0 with a 42RE. What's happening is when put it into drive it takes alot of gas to make it move. Feels like it's stuck in 2nd or 3rd gear when you go to take off or like there's major brake drag. I can shift it one, two and drive no problem. Goes into reverse no problem. I changed the fluid and filter but didn't help. I also had it scanned for codes, no codes. It was showing no governor pressure tho. Anybody else ever had this happen?
MadMattster is offline
post #2 of 26 Old 12-26-2012, 12:14 AM
KoreaZJ
1994 ZJ
Welcome to JF!
Mine had same symptoms when governor pressure solenoid and pressure sensor went bad.
With no governor pressure, possibly bad governor pressure solenoid and pressure sensor... which should throw a code.
Try the key trick and look for tranny fault codes on the OD ON/OFF lamp.
Learn how... HERE
Does TCM have power?
Check Fuse#F3(20amp) in the PDC under the hood. Check for +12v on both sides of the fuse.
KoreaZJ is offline
post #3 of 26 Old 12-26-2012, 07:32 PM Thread Starter
MadMattster
I tired the key code trick. All I get is code 55.
Checked fuses, all good. Power is there.
post #4 of 26 Old 12-26-2012, 07:35 PM Thread Starter
MadMattster
When it's cold first thing in the moring it does it briefly in reverse now too. No codes, nothing. Would a bad TCM at least throw a code?
post #5 of 26 Old 12-26-2012, 08:26 PM
LordHobbit
If it is just for a brief moment, don't worry about it. Just let the fluid build up to pressure before you try to take off.
If its longer than 30 seconds, I'd say you may have other problems.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #6 of 26 Old 12-26-2012, 10:34 PM
papitt
... I'm having trouble with my haul truck .. Dodge diesel ..2000 ... Now if it's cold mine is jumping up & down for 30 minutes before it warms up. Then all is good.
... So the last few mornings it has really been cold here so I have cranked the Truck & my Jeep also .. I put both into Neutral and let them idle for about 20 minutes .. This morning after I let them Idle they both shifted good and it was 17 this AM ..
We were on the cell phones talking about them .
.. When you put them in neutral the fluid can circulate and the trans will work much better.
papitt is offline
post #7 of 26 Old 12-27-2012, 08:41 PM Thread Starter
MadMattster
ya it's a brief moment for sure. The going forward issue I have no idea. Stumped on what to do.
post #8 of 26 Old 01-10-2013, 02:28 PM Thread Starter
MadMattster
Still haven't figured this out.
post #9 of 26 Old 01-10-2013, 06:12 PM
KoreaZJ
1994 ZJ
Verify Throttle Valve cable is adjusted properly...
Verify return spring is connected properly...
(located left side of tranny above the pan)
KoreaZJ is offline
post #10 of 26 Old 01-10-2013, 08:28 PM Thread Starter
MadMattster
I checked the TV kick down cable and spring. Both are good. Even though no code I'm thinking it must be a bad governor pressure solenoid and pressure sensor. When put on the scanner it shows no governor pressure.
post #11 of 26 Old 01-15-2013, 12:03 AM Thread Starter
MadMattster
Nobody has had this happen before? Weird
post #12 of 26 Old 01-15-2013, 12:14 AM
misfit77
This exact thing just happened to me 2 weeks ago. I mean exact. D was sluggish, 1-2-D worked fine, highway speeds fine, OD shifting fine, no clutch slippage,
The shop checked the bands and they weren't bad. They talked me into an entire rebuild.
Cost me an arm, a leg and a rectum, but problem solved and will outlast the rest of my jeep.
If you can afford it..take Korea's advice and replace solenoid.
misfit77 is offline
post #13 of 26 Old 01-15-2013, 05:27 PM
papitt
Well after I reread your 1st post I too would say you need the Governor pressure solenoid and the transducer along with a new filter and gasket your get to change your trans fluid .
.. When I was a service adviser at the jeep dealership . People came in & said it was taking off in 2nd gear and or stuck in 2nd .. Most of the times it was just in need of those 2 parts.
.. Being the genius I am .. I took mine to an cheapo shop a few weeks ago & I too got a complete rebuild and then got those 2 parts installed after my rebuild .. Only cost me a grand. But now my Jeep has several other problems after going to that shop.
papitt is offline
post #14 of 26 Old 01-15-2013, 09:32 PM
jnicewan
Are you checking gov pressure sitting still or moving. If you can read data, you should see a PID for commanded gov press, see if this pid follows actual gov press. FYI gov pressure should be zero at idle and it ramps up about 1 psi per MPH. I wouldnt really worry about the first few miles per hour but you should see a steady increase from 5-10+MPH and above. I find it odd that you might have a gov press problem and no codes. As primitive as these Jeeps and transmissions are/were, they seem to be pretty accurate on finding faults with gov pressure concerns.
The things that worries me the most is you saying it feels like there is a major brake drag feeling. Does this happen in all forward gears or just first gear, or when its in "D" while taking off? Even if there is a gov pressure concern, you should not feel a braking effect, that seems like there is a faulty or burned clutch pack causing a bind or an applied clutch pack or band when it should not be applied
jnicewan is offline
post #15 of 26 Old 01-16-2013, 10:36 AM
misfit77
That's why I prefer to fix my own things. The Jeep dealer here crushed the door on my WK on the lift. The were supposed to program the tire size. Not sure why it was on a lift.
misfit77 is offline
