Do I need a new thermostat? (5.9L) - JeepForum.com
post #1 of 11 Old 11-14-2013, 01:30 PM Thread Starter
leftfield6
Where are my damn keys?
leftfield6's Avatar
So, cooler weather is upon us, and I realize my 5.9Limited takes quite a while to make some dang heat.
Think I may need a new thermostat. This pic shows where my temp gauge sits after about an hour of interstate driving. Sorry for the fuzzy, but I'm snapping a damn pic at 70MPH, as you can see.
That's too low isn't it? Ambient temp that day was mid-50s or so.
Jeepless for now, probably not for long
(former)
98 Grand Cherokee Limited 5.9
98 Grand Cherokee Laredo
77 CJ-5
75 CJ-5
leftfield6 is offline
post #2 of 11 Old 11-14-2013, 01:41 PM
RWC
Could be a bad sending unit too.
RWC is offline
post #3 of 11 Old 11-14-2013, 02:37 PM
StPaul59
Almost looks like you have a 180 stat in there.
StPaul59 is offline
post #4 of 11 Old 11-14-2013, 03:27 PM
riot1987
Could be a thermo. Pull it out, put it in some boiling water and check to see if its opening up or not. Get a 195* one if you decide to replace it
Build thread^^
riot1987 is offline
post #5 of 11 Old 11-14-2013, 04:46 PM
pageman
the old boil test is ok but if you went through the trouble of taking it out just replace it since its a whole 7 bucks.mine drives at that temp all the time too so your not alone
pageman is offline
post #6 of 11 Old 11-14-2013, 04:51 PM
PolkaPower
Looks like it's stuck open. That happened to me when I was using a POS Failsafe. I replaced it with a stock Mopar T stat. The difference in quality when the two are side by side is obvious.
PolkaPower is offline
post #7 of 11 Old 11-14-2013, 06:04 PM Thread Starter
leftfield6
leftfield6's Avatar
Yeah, I think that's the weekend project. Just replacing it. I'm going to the dealer to get an OEM one, too many bad units from the FLAPs
(former)
77 CJ-5
75 CJ-5
post #8 of 11 Old 11-14-2013, 06:44 PM
Gearhead31
mine isn't wanting to get above ~130, gonna replace mine tomorrow morning.. Not sure if you have a 180 therm, yours is shot or if it's something else. If you're willing to put in about $10-12 for quality parts and half an hr of work, go ahead and replace it. With that little cost, it wouldn't be much of a loss if it turns out it's something else and it gives you a definitive answer. Be sure to have two gallons of antifreeze to throw into it afterwards though!
1995 ZJ ltd, 4.0 i6, *cough stock cough* 253,xxx and still pumping strong
1998 Chevy Cheyenne K1500, 5.7L Vortec, mostly stock
*In peace, sons bury their fathers. In war, fathers bury their sons. - Herodotus
Originally Posted by JasonStebbins
We can call it the Whoosh King Catalog System. :D
Gearhead31 is offline
post #9 of 11 Old 11-14-2013, 06:55 PM
steve_up
Flush your heater core as well if possible. I second replacing the tstat, they're cheap and fail.
steve_up is offline
post #10 of 11 Old 11-15-2013, 05:42 PM Thread Starter
leftfield6
leftfield6's Avatar
Okay, it was the thermostat. I went by the Mopar dealer, picked up an OEM thermostat for about $15 with gasket. Super easy R&R. Lost about a 1/2 gallon of coolant, most of which somehow managed to miss the basin I had placed underneath. Kitty litter took care of that. Don't have a cat, but I do have old vehicles, so kitty litter is always in the garage.
Replaced coolant, fired her up and went for a drive. Gauge moved up MUCH faster than before. I had heat coming from the vents in about half the time, a marked improvement from before. Gauge reached what looks like 190* to 200* and stayed right there.
About 20 bucks and about 45 minutes, some of which was spillage clean-up. GTG.
Thanks all.
(former)
77 CJ-5
75 CJ-5
post #11 of 11 Old 11-15-2013, 08:43 PM
Gearhead31
Glad you got it fixed!
