Do I have a limited slip diff? - JeepForum.com
post #1 of 17 Old 09-22-2009, 09:44 AM Thread Starter
eek142
The car is a 1999 Jeep Grand Cherokee 2WD. The differential looks like it's the Dana 35C. Is it limited slip? The reason I ask is b/c I will be changing the oil now and need to know if I should add friction modifiers or not.
eek142 is offline
post #2 of 17 Old 09-22-2009, 09:46 AM
theducksguts
no, the C just means custom, meaning it came from Dana without axles or internals. You should have a tag in you're glove box which would state whether or not you have LSD. My guess is that you do not.
Check out my
theducksguts is offline
post #3 of 17 Old 09-22-2009, 10:41 AM
the88thpianoman
2003 WJ
The C indicates that it uses a C clip inside the diff to hold the axles in.
Easiest way to tell if you have a LSD or open diff is to jack up the rear end of the Jeep, spin one tire. If the other tire spins in the opposite direction, it's an open diff. If it spins in the same direction, it's a LSD.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #4 of 17 Old 09-22-2009, 10:59 AM
squashman702
1994 ZJ
Easiest way is to take the VIN to a dealer or email Chrysler and ask for a build sheet.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #5 of 17 Old 09-22-2009, 12:41 PM
StrokedWJ
StrokedWJ's Avatar
Nope, not in WJ's. gilandj was right on the money. With a 2wd WJ, I'd say there's pretty much a 0% chance that you have an LSD. The trac-lock was a VERY rare option in early WJ's and I can't see a 2wd being ordered with one...
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #6 of 17 Old 09-22-2009, 12:56 PM
spife7980
and the easiest way yet to tell is to crawl under it, look at the diff tag, and see if it says "L S" on the tag.
if theres no tag go pianoman's route
-James
Got to love an ORVIS guy...
IRO 5.5", Front LA & Double Sheer TB, Rear Adj SA and TB, JKS Quick Discos, Bilstein 5125, 265/75/16 Nitto Terra's, Cragar 16x& Soft 8s 4" bs
JCR Stage 2 Sliders, IRO Trans Skid, Carolina Drive shaft, IRO exhaust
spife7980 is offline
post #7 of 17 Old 09-22-2009, 01:22 PM
rugermack
The "c" stands for "custom" because it was supplied by Dana for Chrysler, without axles or bearings. It also had a larger ring gear(from 7.562" to 7.79") and 7/16" bolts instead of 3/8's. Any d35 from 90' and on has "c' clips,
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #8 of 17 Old 09-22-2009, 02:03 PM Thread Starter
eek142
Hey everyone. I just took off my differential cover and the rear of the car is in the air right now. There is this weird circle on the inside of the diff cover by the drain plug with an "X" inscribed in it and it seems to be full of something like anti-seize. Any idea what this is? I've never seen something like this before. Should I clean it out or leave it alone?
eek142 is offline
post #9 of 17 Old 09-22-2009, 02:17 PM
theducksguts
Is there a magnet on it? Sometimes the plugs are magnetic to catch any small metal shavings.
Check out my
post #10 of 17 Old 09-22-2009, 02:19 PM
theducksguts
Is this a metal plug or rubber? Is the stuff(anti-seize) hard or soft? I don't think someone would use anti seize for this. it might be dried RTV
Check out my
post #11 of 17 Old 09-22-2009, 02:20 PM Thread Starter
eek142
The plug itself is rubber. This is above the plug and cannot be seen from the outside. I was thinking it was a magnet, but I just touched a bolt against it and I didn't feel anything. Truly odd. It's got a silver paste all around it.
eek142 is offline
post #12 of 17 Old 09-22-2009, 02:21 PM Thread Starter
eek142
The paste is soft like fresh aluminum anti-seize compound. It's the same color too. I have no idea what it is.
eek142 is offline
post #13 of 17 Old 09-22-2009, 02:44 PM Thread Starter
eek142
it was a magnet. cleaned it off
eek142 is offline
post #14 of 17 Old 09-22-2009, 02:54 PM
theducksguts
I don't know man. I don't know.
Check out my
post #15 of 17 Old 09-22-2009, 03:01 PM
theducksguts
When in doubt post pics.
Check out my
need help with switching stock rear diff for a limited slip diff jbearss04 ZJ Grand Cherokee Forum 4 09-02-2010 11:53 AM
limited slip diff additive??? painted600rr ZJ Grand Cherokee Forum 8 03-08-2009 11:19 PM
Limited Slip Rear Diff? nick500ss WK Grand Cherokee & XK Commander Forum 7 04-18-2008 08:09 PM
Limited slip diff laxwarriors21 ZJ Grand Cherokee Forum 5 02-22-2005 09:43 PM
75W-140 Synthetic Oil for Limited Slip Diff -- where to get it? jo8243 ZJ Grand Cherokee Forum 3 11-20-2004 09:13 AM
