Do I have 42RE or 42RH Transmission? - JeepForum.com
post #1 of 13 Old 01-08-2006, 10:04 AM Thread Starter
blacklimited
1997 Jeep Gr. Cherokee Limited w/ overdrive.
4.0 L In Line 6-cyl.
I know there's a code, but I don't know how to figure it out. I'm adjusting the trans. bands and there's a difference between the RE and RH for that.
Thanks for your help.
1997 Jeep Grand Cherokee Limited
4.0L 6-Cylinder
blacklimited is offline
post #2 of 13 Old 01-08-2006, 10:24 AM
table
table's Avatar
2015 JK Wrangler
Try emailing Jeep for a build sheet, you'll need to send them your VIN. - they'll give you your tranny info and a whole lot more.
Click on "I need customer assistance" :
http://www-5.jeep.com/webselfservice/jeep/index.jsp
2015 Anvil JKU | Sahara | Manual | 3.73
RIP: 2000 WJ | Initiated Destruct Sequence One | Code: 11A
table is offline
post #3 of 13 Old 01-08-2006, 10:30 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I am going to say 42RE since the only other automatic transmission mated with the 4.0 in a ZJ was the AW4 and you don't have that. I thought the 42RH (or 46RH?) was a V8 transmission
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 13 Old 01-08-2006, 10:46 AM
RyanZJ
RyanZJ's Avatar
I think you have a 42RE, just because I think they switched from the RH in 95(?).
Arlo, the ZJ V8s have 44RE/RHs (depending on year), and 5.9s have 46REs.
Edit: Just looked at my '97 FSM. You have an RE for sure.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #5 of 13 Old 01-08-2006, 11:00 AM
ArloGuthroJeep
Mr. Hyde!
Gotchya
So early 4.0 ZJ's had the 42RH?
post #6 of 13 Old 01-08-2006, 11:07 AM
RyanZJ
RyanZJ's Avatar
Originally Posted by ArloGuthroJeep
Gotchya
Yep. I'm not sure what year they changed, though.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #7 of 13 Old 01-08-2006, 11:32 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
The 93-95 5.2's have the 46RH, the 96-98 5.2's have the 44RE and the 5.9 has the 49RE just to clear that up
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #8 of 13 Old 01-08-2006, 11:32 AM
-Joe-
-Joe-'s Avatar
The 42RE 4 speed automatic transmission was used in 1993.5 to present Jeep Grand Cherokees with 4.0L engines
The 44RE 4 speed automatic transmission was used in 1996 to present Jeep Grand Cherokees with 5.2L engines.
The 46RH 4 speed automatic transmission was used in 1993 to 1995 Jeep Grand Cherokees with 5.2L engines.
http://www.off-road.com/jeep/tech/trans/42re.html
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #9 of 13 Old 01-08-2006, 11:53 AM
RyanZJ
RyanZJ's Avatar
Its about time we got some people in here that know what they're talking about.
Ryan
'98 ZJ V8 Limited
'06 WK V8 Laredo
'51 CJ-3A
RyanZJ is offline
post #10 of 13 Old 01-08-2006, 12:07 PM Thread Starter
blacklimited
good help
thank you everybody....
4.0L 6-Cylinder
post #11 of 13 Old 01-08-2006, 06:04 PM
skier123
Dont forget about us with the AW4!!
late 92(yes there are a few!) to 93.5.
skier123 is offline
post #12 of 13 Old 01-08-2006, 06:17 PM
-Joe-
-Joe-'s Avatar
I only pasted a few of them.. Click on the link and you will see most if not all listed..
- Joe -
-Joe- is offline
post #13 of 13 Old 05-09-2009, 06:44 AM
1BADCJ8
Junior Member
1BADCJ8's Avatar
1982 CJ8
New twist to the Post!
OK this is an old post but I found it in my search so I thought it best to bring it up again here.
Did any of these transmissions share the same transfer-case? Say a 46RH or a 42RE share the same case as the AW4?
Meaning that the bolt up on the rear of them are all the same?
Danno -
'82 Scrambler, 360-727, 60&14B, 4 Link Rear, 40's & some other stuff...
1BADCJ8 is offline
swap a 42RE for 42RH a70eliminator ZJ Grand Cherokee Forum 11 12-22-2010 10:47 AM
42re and 42rh. Whats the difference? psyviperx ZJ Grand Cherokee Forum 10 11-11-2009 07:46 AM
42re and 42rh difference justinspotanske ZJ Grand Cherokee Forum 7 11-01-2009 09:24 PM
42re Transmission??? 92cherokeesport ZJ Grand Cherokee Forum 9 12-27-2005 11:00 PM
Transmission Again!!! 42RE or 42RH??? crazynut52 ZJ Grand Cherokee Forum 2 02-07-2003 06:55 PM
