-   -   dnuccio's starter replacement tips and tricks (http://www.jeepforum.com/forum/f13/dnuccios-starter-replacement-tips-tricks-1580993/)
dnuccio 09-13-2013 12:41 AM
had to change the starter in my ZJ today, just thought I would post a couple tricks i found that make the job a little easier. this is for the V8s, i have the 5.2 but i would think these would still apply on a niner
1. unbolt the starter from the trans before you try to get at the electrical connections
2. once unbolted, carefully turn the starter upside down. this will give easy access to the electrical connections
3. its easiest to bring the starter out over the front axle, rather than try to fit it past the exhaust and upper control arm
starter mounting bolt and nut are 16mm, positive battery cable connection is a 13mm, and the smaller electrical connection is a 5/16.
hopefully this helps someone
bjorn17 09-13-2013 01:07 AM
Safety first though! Disconnect the battery. The starter positive wire is unfused and thick enough to melt the battery down if something should happen.
dnuccio 09-13-2013 08:48 AM
d'oh! I forgot to mention that. Good catch
riot1987 09-13-2013 09:48 AM
I pulled the started in my 4.0 so many times I could do it with my eyes closed. Literally. Worst part is every nut is a different size. Drove me crazy
The time now is 01:00 AM.
