Quantcast Ditch the manual fan for dual electric's on 04 WJ? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ditch the manual fan for dual electric's on 04 WJ?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 02-03-2008, 11:10 AM   #1
TheSandman
I know the WJ's come with an electric aux fan for the manual fan, but I was thinking of ditching the manual all together for a universal dual fan setup for fuel economy? I know it's a clutch fan and should disengage under power, and it does fine, but I've never been a fan of manual fans. Has anyone ever done this?
04 WJ 4.0 - Stock
96 XJ 4.0 - RE 7.5" LA, Locked HP44/9", 36 TSL's soon
TheSandman is offline   Reply With Quote
Old 02-03-2008, 11:21 AM   #2
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Hmmmm, you sure you have a manual fan at all? I just have an electric fan.
ArloGuthroJeep is offline   Reply With Quote
Old 02-03-2008, 11:28 AM   #3
TheSandman
Guess I should have said I have a 4.0 and yes I do have a manual fan.
04 WJ 4.0 - Stock
Old 02-03-2008, 12:18 PM   #4
georged
If it is a factory electric fan it is not manual, as a thermostat turns it on and off.
georged is offline   Reply With Quote
Old 02-03-2008, 12:33 PM   #5
TheSandman
I'm confused
I mean it's manual as it's connected to the water pump and runs, not an electric fan which is activated via computer
04 WJ 4.0 - Stock
Old 02-03-2008, 01:07 PM   #6
georged
I'm confused
Now I am very confused! If you have a 2004 6 cylinder GC, you have a factory electric fan. If the fan blade is connected to the water pump someone changed it.
Old 02-03-2008, 02:11 PM   #7
nitecop
I'm not sure about the v8s but most of the 4.0 WJ that had the towing option got BOTH (belt driven and E-fan) fans.
If your just gonna get rid of it, how much do you want for it? and what is your zip code?
Jim
United Steelworkers Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline   Reply With Quote
Old 02-03-2008, 03:14 PM   #8
TheSandman
It's not aftermarket, it's factory. I do have a tow option so maybe that's why it's on there. My mom bought the jeep new so I know it hasn't been changed. So if I just ditch it, would I be ok? I'd rather have dual fans, maybe I can get dual universal puller fans.....
If I do take it, I don't wish to sell it, I keep everything I take off
04 WJ 4.0 - Stock
Old 02-03-2008, 06:37 PM   #9
CMARJEEP
ive been wondering this also. i know some jeeps only have electrical fans but i have noticed that mine has the mechanical and the electric. so if the mechanical is taken out will it affect the the temperature of the engine and will it give better performance?
-Connor KI6TMX
www.norcaljeepers.co
CMARJEEP is offline   Reply With Quote
Old 02-03-2008, 06:54 PM   #10
MSU.WJ
There was a 'max cooling package' that gave you the mechanical clutch-driven fan plus the electric fan... I personally have both fans on my 4.7.
Theoretically, if you took out the mechanical fan you would have less parasitic drag on the motor and you could potentially gain some mpg's... I would replace it with another electric fan as the initial post suggested.
2000 WJ Laredo 4.7 NP242
3" Lift, 31" MT/Rs, Aussie Locked D44A, JKS sliders, more
Want places to wheel? Support the Blue Ribbon Coalition: http://www.sharetrails.org
MSU.WJ is offline   Reply With Quote
Old 02-03-2008, 07:23 PM   #11
CMARJEEP
i wonder if you put a second electric fan in if you could splice into the stock fan's thermometer.
-Connor KI6TMX
Old 02-04-2008, 06:00 AM   #12
TheSandman
I wonder if I could do away with the manual and the electric and go with a whole new dual fan setup.
04 WJ 4.0 - Stock
Old 02-04-2008, 08:21 AM   #13
ArloGuthroJeep
Mr. Hyde!
My electric fan is as big as it can get - is your electric fan smaller? Where do you plan on putting the electric fan?
Old 02-04-2008, 09:56 AM   #14
MSU.WJ
It's an electric fan the size of the radiator.. not real "thick" though compared to the pitch of the blades on the clutch-driven fan.
Old 02-04-2008, 10:25 AM   #15
LEDFoot
If I am not mistaken the towing package for the 4.0 came with a "heavy duty" manual fan rather than the all electric one because it doesn't have enough cooling capacity.
--Martin
_____________________________________
'99 WJ 4.7 Quadra-Drive w/ 242HD swap... 2WD since my front diff is kaputt :(.
LEDFoot is offline   Reply With Quote
Glock Forum
