Distributor Cap Removal from 94 Grand Cherokee V8 - JeepForum.com
post #1 of 21 Old 08-21-2003, 05:14 PM Thread Starter
ruth
I'd like to remove the distributor cap from a 94 Grand Cherokee V8 but I can hardly get to the retaining screws. If I do get to them, there seems little room to take the cap off. Anyone help.
Thanks
ruth is offline
post #2 of 21 Old 08-21-2003, 05:52 PM
JEEPTECHNICIAN
take the cruise cable loose from the bracket and it will come out from behind the throttle body.
JEEPTECHNICIAN is offline
post #3 of 21 Old 08-21-2003, 06:02 PM
Stocker
Hey, first post! Welcome to the boards!
Your 94 should be like my 95. Very tight fit but there's no tricks that I know of, just be patient and take your time. A fairly short screwdriver helps get the screws out, then work the cap out on the driver's side. It's a squeeze and some people remove a few things (throttle cable, I think), but I didn't remove anything and it went OK - but it's VERY tight! Dumb design IMO...
Good luck with yours...
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #4 of 21 Old 08-21-2003, 08:58 PM
RockPaws
RockPaws's Avatar
I have found its best to remove one side of the ignition wires. At the same time replace it anong with the rotor.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #5 of 21 Old 08-22-2003, 08:03 AM
Swamp Boy
Swamp Boy's Avatar
Yeah I have done mine as well.. I thought it was easiest to pull all the plug wires. and then Just remove the cover.. reinstall the same way.. If the wires are off you are free to move it around much more...
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #6 of 21 Old 09-05-2010, 06:35 PM
tylersjeep
1994 ZJ
94 grand cherokee v8 tune up what the ****
okay guys i need help with removing the distributor cap its a night mirror. i spent 8hr trying to get the ****ing distributor cap off there no room to get it out from behind there. i wont to shot the guy who made this. i broke two flash light and smashed them on the ground. please anyone if you have a video or pic on how to do this i'm sitting here with a dead car in my yard because i cant get the cap off please helpppp me before a start my car on fire. this is ****ing retarted
tylersjeep is offline
post #7 of 21 Old 09-05-2010, 06:46 PM
melk
Notch one for the 4.0!
melk is offline
post #8 of 21 Old 09-05-2010, 07:26 PM
tylersjeep
1994 ZJ
please help someone i have no idea how to get distributor out from the back of the engine? i spent 8 hrs today trying to get this thing out and broke two flash lights kick my car and threw a reachet at my house and i'm sitting here with a dead car. any help would be great plus pic or video i have a v8 5.2. the guy who made this should be shot
post #9 of 21 Old 09-05-2010, 09:43 PM
SBlackfoot
First off, stop throwing stuff around. That's not helping.
Bad design maybe, but it IS doable. Two screws on the cap, undo the leads (label first if necessary), remove a cable from the throttle body if necessary, and there's room to wiggle it out. A pain in the butt for sure but way easier than say, doing a t-case swap. The most frustrating part is trying to reach it in the first place, it's a long stretch and I'm 6'4". lol
'98 Grand Cherokee Limited, 5.9L, daily driver.
'98 Grand Cherokee Limited, 5.9L, $650 project.
'93 Grand Voyager wheelchair van, 3.0L, chick magnet.
'90 Trans Am GTA, 5.0L/700R4.
'98 Oldsmobile LSS, 3.8L.
SBlackfoot is offline
post #10 of 21 Old 09-05-2010, 10:21 PM
tylersjeep
1994 ZJ
got any pic? and is there any other way? and ya. i spent 8 hrs today and it was the the biggest waste of time 30mins on spark plugs 3hrs trying to get the scrows out and 3hr and a half trying to get the cap out still no luck. i see that there are a lot of ways to do this? why does it take the sealership 45 to a hr to do this and i spent the whole day and still not done. the transfer case took me 15hr total. this job is going no where fast. I'm also 6'4 and ya. is there any other way to get this thing out without taking stuff apart? and does it have to come out the passanger side or can it come out the driver side. any pic would be wonderful or videos. i dont no what to take apart? I took the air filter off and some other stuff on the driver side no luck. again a pic or vdeo would be very helpful. thanks
post #11 of 21 Old 09-06-2010, 11:27 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
there's room on either side. remove the tb if needed(it's not that big of a deal. i can pull mine in about 10mins). you will need to pull the air hat to get more room for you to work with.
remove the plug wires, label if needed. firing order is on the manifold. use a stubby screwdriver or nut driver to unscrew the bolts, pull upwards and tilt it while pulling out the pass side.
and a nut for you 4.0 guys, i've seen the screws corroded so bad on an xj that he had to drill them out. much nicer with nothing getting to the zj cap.
ratmonkey is offline
post #12 of 21 Old 09-06-2010, 12:31 PM
gregs887
Up your butt Jobu
gregs887's Avatar
Stubby phillips head screwdriver and bandages for your soon to be bloody knuckles. It helps to tape a list of curse words to the underside of the hood to use as a reference. I had to use a ladder and pretty much sit on the engine to reach mine. Good luck!
Greg
Never underestimate the predictability of stupid- Bullet Tooth Tony
gregs887 is offline
post #13 of 21 Old 09-06-2010, 01:33 PM
NJSPEEDER
I struggled with the same thing doing the first tune up on my '93 recently. As one of the other responses suggested, take the TV/cruise cables off, it makes a ton more space.
I couldn't get to it with a stubby screw driver so what I did was take a chinese phillips head that I had and cut the handle down. With the wires all pulled off and a short handle on a regular length screw driver it was easy.
-Tim
Tim Mullaney
1993 Jeep Grand Cherokee Larado
1999 Chevrolet Camaro Z28
New Jersey F-Body Owners Association
NJSPEEDER is offline
post #14 of 21 Old 09-06-2010, 01:50 PM
ZJ5point2GCL
take all the wires off, take the throttle body off, stubby philips screw driver for the cap, cap comes out best on passengers side.
first time took me about 5 hours (my t-case on took 2) and i broke my wrist and dislocated me elbow in the process. But now i think i do it it all in under 45 mins
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #15 of 21 Old 09-06-2010, 05:48 PM
tylersjeep
1994 ZJ
hey guys i got the cap off and did the tune up now i'm having this problem
i just did a tune-up on my 94 grand cherokee v8 5.2 and i'm getting a ticking sound and extreme vibration when i hit the gas padal nothing well i'm coasting. it did not do this before the tune up. i was wondering would it do this if all the wires are not hook in right? or firing order was wrong? i'm talking like hydro massage vibration plus buring smell and i sound like i'm drag racing. please heeeellllppp
99 Grand Cherokee Dash Removal Cactus52 ZJ Grand Cherokee Forum 5 01-03-2010 03:25 PM
Grand Cherokee Emblem Removal Oppeau ZJ Grand Cherokee Forum 3 11-14-2005 04:50 PM
Cap and Rotor Removal for 95 Grand Cherokee... G4teamG ZJ Grand Cherokee Forum 12 06-27-2005 05:24 PM
Grand Cherokee Badge Removal '95 ZJ SkyjacktZJ ZJ Grand Cherokee Forum 6 11-17-2004 05:46 PM
Dash removal on 98 Grand Cherokee twozzie ZJ Grand Cherokee Forum 4 07-23-2003 02:20 PM
