display module - JeepForum.com
post #1 of 7 Old 02-19-2013, 06:33 PM Thread Starter
93zjgrand
display module
my zj didnt come with a display module, i checked ebay and theres 3 differnet ones, do they all use the same connection and mounts
93zjgrand is offline
post #2 of 7 Old 02-19-2013, 08:32 PM
jmonty0523
They all usually have the wiring in there somewhere, or at least ones build for that year. you can't put the '98 VIC in a '93, wiring is different. Also you might not have sensors for the more optioned one. do your research before buying the parts...
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #3 of 7 Old 02-19-2013, 08:53 PM
KoreaZJ
1994 ZJ
Top = VIC (Vehicle Information Center)
Bottom = GDM (Graphics Display Module)
GDM might work if wiring is there, but doesn't offer much information on the display. 4WD mode.
You wouldn't have sensors required for VIC warning functions. With some wiring mods, might be able to fake VIC into thinking the sensors are there to prevent warning messages. Then you'd have date/time/4WD display. Could even wire up the "door open" function/display.
Connectors/pinouts changed in '96.
KoreaZJ is offline
post #4 of 7 Old 02-19-2013, 08:58 PM
Primordial
Yeah I bought one for my 95 that came with a GDM. The VIC wouldn't even turn on even though it plugged in. Plus a lot of people say they have a lot of problems with them.
Primordial is offline
post #5 of 7 Old 07-03-2013, 10:42 PM Thread Starter
93zjgrand
i have the GDM not the VIC. will the vick plug right in.
post #6 of 7 Old 07-04-2013, 01:58 AM
AVR2
You *probably* have the necessary harness connectors tucked away behind the dash, but you'll be missing some of the sensors the VIC looks for.
Note that the 93-95 VIC uses two plugs, and the 96-98 VIC uses one.
AVR2 is offline
post #7 of 7 Old 07-04-2013, 03:51 PM Thread Starter
93zjgrand
i have the coolent sensor, and fluid sensors,
