Disc Brake Conversion? - JeepForum.com
post #1 of 10 Old 06-18-2011, 10:00 AM Thread Starter
MrKeebler26
1994 ZJ
What are the thoughts of those who have converted the Dana 35 from Drum to Disc brakes?
If you have what kit did you use.
My drums are in need of a rebuild and the cost is nearly half way to the Summit kit that I found... makes me think that going the extra mile may be worth it.
If i decide to go with it I will shoot full video and stills for a build thread.
MrKeebler26 is offline
post #2 of 10 Old 06-18-2011, 10:19 AM
Dodgeram1989
1976 FSJ Cherokee
What about just swapping in a Dana 44a with disc brakes. Seems like that would be the cheapest way to go. And you would be upgrading axles at the same time.
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #3 of 10 Old 06-18-2011, 10:47 AM
blackjack12982
1994 ZJ
Because that would require him to swap 2 axles instead of just the brake components. If you had thought about this for more than 3 seconds you could've noticed his gearing is 3.55 :
blackjack12982 is offline
post #4 of 10 Old 06-18-2011, 10:50 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
you can pull the disks off of a D44A and swap them right over, thats what the cherokee guys do.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #5 of 10 Old 06-18-2011, 10:54 AM
blackjack12982
1994 ZJ
Crap, I forgot to even put that in my reply...
post #6 of 10 Old 06-18-2011, 11:02 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Jeep D35 and D44a disk brakes are a bolt on swap for any C-clip D35. Install the disk brake proportioning valve for a disk brake ZJ at the same time.
CJ7-Tim is offline
post #7 of 10 Old 06-18-2011, 05:03 PM Thread Starter
MrKeebler26
1994 ZJ
Okay so how do i know, short of opening up the diff if it is a c-clip axle or not?
post #8 of 10 Old 06-18-2011, 05:05 PM
blackjack12982
1994 ZJ
It is...
post #9 of 10 Old 06-18-2011, 05:43 PM Thread Starter
MrKeebler26
1994 ZJ
Originally Posted by blackjack12982 View Post
It is...
Cool thanks. Going to go digging at the salvage yard tomorrow.
post #10 of 10 Old 06-18-2011, 09:14 PM
Foundrydude
You're probably not going to find used disc ebrake hardware worth a darn. They're generally a ball of rust. Poor combination of design and materials.
Foundrydude is offline
Drum to Disc Conversion? jordanhoff ZJ Grand Cherokee Forum 2 08-14-2009 09:47 PM
Hardware necessary for '94 ZJ disc conversion? compugeek ZJ Grand Cherokee Forum 3 08-12-2009 07:28 PM
'93 ZJ Disc brake conversion mykol93 ZJ Grand Cherokee Forum 11 11-19-2007 02:56 PM
disc brake conversion for 6 lug dana 44 legend6009 ZJ Grand Cherokee Forum 3 01-28-2007 10:42 AM
Rear Disc conversion? rim_bender ZJ Grand Cherokee Forum 2 04-18-2006 09:38 AM
