Direct bolt up or not? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Direct bolt up or not?
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-16-2012, 07:54 PM   #1
Niles19
Does anyone know if a Dana 30 HP from a cherokee is a direct bolt in for a ZJ with a 242 TC?
Niles19 is offline   Reply With Quote
Unread 03-16-2012, 08:37 PM   #2
nicklopic
Yes, you need a lift though iirc do to clearance issues
Search for the other threads for more details
98' Grand Cherokee 4.0, 3" lift (2" BB and upcountry springs) 32" BFG All-Terrains
Aluminum Rad, Hella 500ff's, Cobra CB, 102" whip, IRO exhaust, Super 40 Magnaflow Cat, Kenwood deck, Kicker DS65 speakers, Sony Xplod amp, Kicker Comp10s in a sealed box
nicklopic is offline   Reply With Quote
Unread 03-16-2012, 08:38 PM   #3
ahoyt653
I would like to know too because I pulled one that has 3.77 gears and want to throw it in!
ahoyt653 is offline   Reply With Quote
Unread 03-16-2012, 08:39 PM   #4
E-rok
you need adjustable LCA's since the HP30 doesnt have the caster slot like the LP ones IIRC
96 ZJ Limited 5.2
E-rok is offline   Reply With Quote
Unread 03-17-2012, 12:09 AM   #5
ahoyt653
I am going to build upper control arms for the rear, can't I just build uppers for the front too as long as I have the caster correct when I fab them?
Unread 03-17-2012, 04:41 AM   #6
Technohead
Old school
Technohead's Avatar
Good luck getting it right. The manufacturers can't even get it perfect so they build in adjustability.
And don't be surprised if the front driveshaft is too long.
Technohead is offline   Reply With Quote
