-   -   Difficult to Replace Computer? (http://www.jeepforum.com/forum/f13/difficult-replace-computer-1535508/)
jlconlin 06-12-2013 09:46 AM
I've been told that the "computer" needs to be replaced on my 1997 Grand Cherokee. I can replace most parts in my Jeep if someone will just tell me what needs to be replaced.
Is the computer easy to replace in the 97 Grand Cherokee? I really don't want to pay someone $500+ to replace it if it is easy enough and I can get the part for about $200.
Thanks,
Jeremy
RnEmOvr 06-12-2013 09:49 AM
Disconnect battery, undo 4 bolts and unplug then reverse for install
DNFJ 06-12-2013 09:49 AM
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
If I recall correctly still need to get it flashed by a dealership.
jlconlin 06-12-2013 09:59 AM
Doesn't sound too bad. Maybe I'll get my 9-yr old son to help me out.
The parts I've seen at Autozone and OReilly websites don't mention that they need to be programmed "zapped" after installation. (Some of them do, but most do not.) Does anyone have experience with this?
jlconlin 06-12-2013 10:00 AM
I've seen several parts online that don't need to be programmed or flashed. Is this believable?
dellis 06-12-2013 10:07 AM
Yes, it has to be programmed for your car ... otherwise, it is just a piece of hardware without software. Costs about $80 for the software installation.
Some of the on-line retailers (on eBay for example) will do the programming for you.
Make sure you buy a "re-manufactured" unit, and not one that has been spit-polished.
Oldfrog 06-12-2013 10:56 AM
The 97 model does NOT need to be flashed. I have a 97 and have replaced the PCM ( more than once).
How do you know that you need a new PCM ?
dnuccio 06-12-2013 10:58 AM
careful buying used PCMs, they are known to go bad after sitting disconnected from the vehicle
Texas ZJ1 06-12-2013 12:03 PM
I have a 94 regular pcm. Who wants it?
jlconlin 06-12-2013 12:50 PM
I took it to a mechanic who drove my Jeep around and couldn't replicate my problem. Then, when he wiggled the PCM, the Jeep immediately killed. It makes sense that the PCM needs to be replaced. Is that too premature a diagnosis?
(My original problem was that my Jeep didn't run well. It backfired, stuttered, sometimes died while running, and had difficulty starting.)
OverlandZJ 06-12-2013 01:28 PM
Common issue.. the problem is the contacts from ECU to harness. Lots of guys have disconnected, cleaned and reassembled. Use a few zip ties if necessary.
Do some searching here... several threads covering it.
MyKeyB 06-12-2013 02:07 PM
I'd try this first:
http://www.jeepforum.com/forum/f13/i...l-fix-1487443/
It's nothing else, it's free.
jlconlin 06-12-2013 02:24 PM
Thanks for those comments. I'll see if I can clean up the contacts and other simple maintenance and save me a few hundred bucks.
shackwrrr 06-12-2013 09:29 PM
The only thing that need programmed on a new ECU is the vin, Everything else will function as designed and run fine if no other issues are present. The only thing that will happen is the check engine light will be on with a code P0630 which just means VIN mismatch or not programmed.
Oldfrog, do you have a security system factory? Im asking because if you use a used PCM with some kind of vin in it no codes will set if there are no other modules in the system that have the vin in them.
Oldfrog 06-12-2013 11:50 PM
No factory alarm on mine. I have only bought refurbed PCMs, never any "used" PCMs....like from Ebay or a JY, etc. ( I know they are all technically "used" because they no longer make new ones. You get my point, I'm sure)
The 97 pcm doesnt need any programming. Never has the question of a factory alarm even arisen when I bought them....not from Cardone, anyway. My guess is that the BCM or some other system is storing that info. Zeejay will know the answer to that one.
To the orginal poster, I suggest he remove Negative battery cable, then the PCM connectors, spray the heck out of them with electrical contact cleaner, let them dry, apply a TINY bit of dielectric grease to the female side of the connector at the pin holes, carefully reinsert them, make sure they are locked down and then zip tie each one. Only if the ZJ makes it 200+ miles without a stall or near stall, will he know if that's the issue. 400 is better.
But if he has some other issue that has caused the stalling ( see Zeejay's list and "work" it...) it may well have messed up the PCM. Plus, they ARE known for having poor solder joints inside. Do NOT, I repeat....do NOT buy a PCM from either of those outfits in Florida. Yes, they are on ebay too. Don't say I didnt warn you. If you are certain you need one, go to Oreilly's,etc. and get a Cardone brand. Keep the receipt, for the warranty because it's hit or miss with some of these PCMs. Or you could get one from Kolak, here on the forums.
The time now is 03:10 AM.
