#1 | |
Differential fluid change
Well i got most on the info from the forum. I bought two 4 oz. bottles of the Mopar Limited slip additive from the stealership. Next what type of gear oil should I use for the front and back differentails. Do they use the same oil front and back diffs. They are sold in quarts at the stores. Also do I use the whole bottle of limited slip additive. One for the back and one for the front! 249TC by the way.Thanx!!!
#2 |
I ate what?
I use a 75W - 140 Synthetic Gear Lube and I noticed on my diff cover it said 2oz. on the inside cover for the friction modifier, but when I picked it up from the dealer, I specifically asked do I just add half to each axle and he said "no" pour the whole thing in (one bottle for each axle), I showed him the cover and he said, all our techs were told to add the whole bottle to each axle. So that's what I do.
Ken 99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 33" Yokohama Mud Rovers 2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Falken 912's (13.76 @ 103.85) 2006 Pontiac G6 GTP - (her's) 2001 Dodge Ram 1500 - CAI, Soft 8's, 31's 2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch 2006 Triumph America 900 - Full Dresser January 2009 Grand Cherokee of the Month (GCOTM)
#3 |
Be prepared to stink. I hate that stuff. I use the 75W140 Mobil 1 also in both differentials.
Kent '06 XK Limited, 5.7L Hemi, Quadra-Drive II, Black, 89K Miles '02 WJ Overland, 4.7L HO, Quadra-Drive, Inferno Red, 84K Miles |
#4 |
I ate what?
Yea, it does have that unique smell don't it
#5 |
i put 4 oz in the rear, 2.5 oz in the front. didn't really measure the front just guessed. and yes gear oil freakin' stinks. get that siphone that was posted in the other thread
#6 |
Gee, I hate to be Mr. Obvious, but you could always do just what the factory recommends - in print, not what some high school dropout in a dealership tells you.
#7 |
Mr. Hyde!
You don't have a LSD in the front so there is no reason to be any addative up front.
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#8 |
my info was from wjjeeps.com
oh and i have quadra drive, which is why i put it in the front. |
#9 |
i just did this last weekend. 3 quarts will do ya. the book says 3.1 pints per, 2 pints in a quart and so forth. I used royal purple, which already has a limited slip additive. if you don't have a siphon, (which I don't) buy a 3-4 feet of 3/8" (I think) fuel line to put on the end of the bottle to fill the diff. fill it until it starts running out the hole. nothing you can't figure out on your own, but there you go
Just because I'm workin' on it don't mean I'm fixin' it... [COLOR="Blue"][B][SIZE="3"]US Navy Jeep Club Hull#43[/SIZE][/B][/COLOR] [COLOR="Red"]NEBRASKA JEEP CLUB Member #1[/COLOR] [URL="http://www.jeepforum.com/forum/showthread.php?t=330993"][B][COLOR="Black"]5.9 LITRE Club Member #1[/COLOR][/B][/url] |
#10 |
i tried filling it with a tube and funnel, damn thing was messy and didn't work. maybe i'm just an idiot. but i'd buy a siphon, it's only 15$
#11 | |
I ate what?
#12 |
well i didn't use a funnel, just put the tube on the end of the bottle and squeezed
#13 | |
Mr. Hyde!
#14 |
Original GC'er
![]() see that tube thingy on the top off the bottle.? BUY IT! Will make filling the diff 10 times easier. oh yeah and dont forget to use RTV sealant I did and now I have to redo it. As for how to not make a mess with it maybe sure it is on the bottle tightly but not over tight. Also you can turn it on and off.... turn it off.. put the hose in the fill hole... turn it on. It be comes harder to use as the bottle becomes less full. I suggest buying two bottles and combining them when they become half empty.
1993 Jeep Grand Cherokee Limited 4.0L I6 - OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap - 1970 Jeepster Commando 225 V6 32"x11.5" BFG A/T 4" Lift 1987 Suzuki LT230S Quadsport 1996 Artic Cat ZR580 EFI 2005 Honda TRX450R "For every one thing I fix two things break" |
#15 |
Mr. Hyde!
I use a pump I bought from Checker...I have two one for quarts and one for gallons. Screws on and has a tube which leads into the fill hole. No bottle to lift
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
