Different tyre sizes front and rear - JeepForum.com
post #1 of 7 Old 02-10-2013, 12:58 PM Thread Starter
Mike2909
A straightforward question hopefully with a straightforward answer.
I have as standard 225/75/16 BF Goodrich tires fitted on my ZJ. I need to replace 2 tires ( rear ones).I have 2 almost brand new 235/70/16 BF Goodrich tires that come off one of my other previous vehicles.
Can I use these 2 tires on the ZJ ?
So I would have 2 x 225/75/16 and 2 x 235/70/16.
My tire place say I can but they are not Jeep specialists.
Mike2909 is offline
post #2 of 7 Old 02-10-2013, 01:17 PM
Myusername1674
What kinda t case do you have? I've heard that if you have the 249, then no you can't. But you'd probably be okay if you have a 231 or 242, if you keep it in 2wd. Is yours a zj or wj? Cause your profile says wj? Maybe you has two? lol
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #3 of 7 Old 02-10-2013, 01:22 PM Thread Starter
Mike2909
Yes sorry , I have 2 Jeeps a ZJ and a WJ. The ZJ is in permanent 4 wheel drive.
Mike2909 is offline
post #4 of 7 Old 02-10-2013, 01:23 PM
WhiteOut
WhiteOut's Avatar
All 5 have to be the same size on the ZJs with fulltime transfer case
WhiteOut is offline
post #5 of 7 Old 02-10-2013, 01:24 PM
lil_joe
If you have the 2wd option on your t-case keep it in 2wd til you get matching tires, otherwise DON'T do it
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #6 of 7 Old 02-10-2013, 01:31 PM
dnuccio
DO NOT put different size tires on a permanent 4wd ZJ. you will destroy the viscous coupler in the transfer case
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 7 Old 02-10-2013, 01:52 PM Thread Starter
Mike2909
Thank you for the information .
Mike2909 is offline
