Different Axle Swap Question - JeepForum.com
post #1 of 9 Old 09-22-2009, 10:40 AM Thread Starter
Orvis97
I have a '97 Grand Cherokee Orvis, and my father has a '95 Grad Cherokee Larado. Both have the towing package, Quadratrac transfer case, 3.73 gears, and the 5.2 V8. Last week he picked his up from having the dealer rebuild the front axle, but as of today the Jeep has started to leak gas into the oil and the rear main started to leak. This is the Jeep we tow behind the motorhome, so we need it to be really reliable, because of that he is planning on selling his '95. Currently my front axle is in desperate need of a rebuild, including a new ring and pinion, so I wanted to know if his axle would be a direct swap for mine, and if not what is difference and would need to be addressed?
Thanks in advance.
2005 TJ Rubicon - 6" Rough Country Long Arm Lift, 35x12.50 Falcon Wild Peak A/T, Body Armor Rockcrawler Side Guards, MOPAR Rock Crawler Winch Bumper, ENGO E9000 Winch, Body Armor Boly in Cage - Mine
1998 Grand Cherokee - Daily Driver/tow rig - 2" BB, 31x10.50 A/T's - nothing special
2012 Grand Cherokee - Wife's ride
2010 JK Unlimited - stock - Wife's Ride! - SOLD
1997 Grand Cherokee Orvis V8 ------ 2.25" BB - SOLD!
Orvis97 is offline
post #2 of 9 Old 09-22-2009, 10:45 AM
the88thpianoman
2003 WJ
To my knowledge it should be a direct swap. They are both ZJ D30 axles, and since you both have the same T case, it will be the same drive shaft and thus pinion yoke. I'm not the expert on this, but I'm about 99% certain it's a direct bolt in swap.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 9 Old 09-22-2009, 10:54 AM Thread Starter
Orvis97
That's where I am, just about 99% positive it is a direct swap. The problem is that I am at work, he is trying to decide what to do with his and wants to know if I want to do the swap, I told him I wanted to do it so he didn't sell his right away, I just wanted some sort of agreement that I was thinking correctly.
Thanks
Orvis97 is offline
post #4 of 9 Old 09-22-2009, 10:55 AM
the88thpianoman
2003 WJ
Thanks
I think you'll be in good shape to count on it being a direct bolt in.
post #5 of 9 Old 09-22-2009, 06:22 PM
sandman
at worst youll need to shorten your front drive shaft and possibly change out the pinion flange but all this stuff can be taken off the donor, front DS, pinion flange and t-case flange. a simple look at the front DS set up will be able to tell you if youll need to mess with that stuff too.
1993 Jeep ZJ. 4.0
sandman is offline
post #6 of 9 Old 09-23-2009, 01:00 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
The 95 is most likely a long pinion d30 and yours is a short pinion. Swap the drive shafts too.
ratmonkey is offline
post #7 of 9 Old 09-23-2009, 05:20 AM Thread Starter
Orvis97
Thanks for all the input, is there any reason that I would not want to do this swap?
Orvis97 is offline
post #8 of 9 Old 09-23-2009, 07:37 AM Thread Starter
Orvis97
Is it going to matter that I have the Up Country suspension and he dosen't when considering the driveshaft length?
Orvis97 is offline
post #9 of 9 Old 09-23-2009, 12:35 PM
sandman
no, theres no reason not to do the swap.
1993 Jeep ZJ. 4.0
sandman is offline
Axle swap question rmtomasin ZJ Grand Cherokee Forum 5 12-01-2009 03:50 PM
ZJ axle swap question 92rslt1 ZJ Grand Cherokee Forum 16 10-24-2009 06:49 AM
wj front cv axle question swap/upgrade roxj ZJ Grand Cherokee Forum 2 11-19-2008 12:32 PM
axle swap question Casper4x4 ZJ Grand Cherokee Forum 29 06-09-2008 01:43 PM
Axle swap question? rustycherokee18 ZJ Grand Cherokee Forum 2 03-27-2008 06:59 AM
