Difference between pressure hose and return hose - JeepForum.com
post #1 of 3 Old 02-06-2013, 09:27 AM Thread Starter
massarosareloud
So I've bought a PSC power steering gear box, and I am trying to get all the questions worked out before I begin swapping the boxes, and all the bolt sizes and information I need.
I can tell the pressure hose is the hose coming out of the power steering pump, and has the heavy duty hose. I can also tell the return hose is the much smaller weaker looking hose that attached into the bottom of the reservoir. My question is how do I know which hose to connect to which opening on my new power steering gear box? I called PSC and they said that the hose openings are different sizes. Also, do you think my fittings from my current power steering box fit in the new one?
Here is the box I bought: http://www.pscmotorsports.com/vehicl...cing-gear.html
1996 Jeep Grand Cherokee Limited Edition 4.0L
3.55 axles, stock pretty much everything, except for a PSC steering gear and fuel injectors
massarosareloud is offline
post #2 of 3 Old 02-06-2013, 11:04 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
They're different fittings, you can't install them wrong.
The psc box uses stock sized fittings.
ratmonkey is offline
post #3 of 3 Old 02-06-2013, 12:27 PM Thread Starter
massarosareloud
Awesome thanks!
