Diff ratio’s - JeepForum.com
post #1 of 5 Old 09-23-2009, 03:20 PM Thread Starter
bucko132
Diff ratio’s
I know this is a really stupid question to many of you but how do I find out what gears I have in my rear diff to see if that mach the front axle I have brought.
bucko132 is offline
post #2 of 5 Old 09-23-2009, 03:29 PM
ZeJokee
There should be a tag on the diff saying if it has 3.55 or 3.73. What engine do oyu have and do you have a factory tow package. You also could request a build sheet from Chrysler. It is located in the F&Q section.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles (SOLD)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
ZeJokee is offline
post #3 of 5 Old 09-23-2009, 03:39 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Open up the diff cover and look on the ring gear for some numbers stamped into it. It'll list the gear ratio and/or the number of ring/pinion teeth. Ring Teeth / Pinion Teeth = gear ratio.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 5 Old 09-23-2009, 03:41 PM Thread Starter
bucko132
i have the 4.0 with the tow package and thankyou for that i will go look in a sec
bucko132 is offline
post #5 of 5 Old 09-23-2009, 03:54 PM Thread Starter
bucko132
its has 3. 73's wich is lucky becouse thats what i brought today. i'm finley going with the 2wd to 4wd convershion
bucko132 is offline
need help with switching stock rear diff for a limited slip diff jbearss04 ZJ Grand Cherokee Forum 4 09-02-2010 11:53 AM
front diff ratio help please cpher ZJ Grand Cherokee Forum 10 05-25-2009 06:17 PM
front diff ratio location cpher ZJ Grand Cherokee Forum 0 05-25-2009 04:37 PM
To rebuild a diff or not to repair a diff? Anto ZJ Grand Cherokee Forum 10 03-23-2009 03:13 PM
How to tell what gear ratio you have? donp ZJ Grand Cherokee Forum 7 06-14-2004 06:17 PM
