Diff lube clarification - JeepForum.com
post #1 of 11 Old 05-25-2011, 03:21 PM Thread Starter
lexo1014
Ive read thru the forums and what i see is 75/140 synthetic will work,i went to the store and can only find 85/140 synthetic and it says limited slip on the bottle.
Will this work? Or should i try to find the 75/140?
By the way its a 98 ZJ
Thanks in advance for your answers
lexo1014 is offline
post #2 of 11 Old 05-25-2011, 05:25 PM
TallyZJ
It will work. Limited slip diffs require a friction modifier additive. While it is necessary to have this for limited slip diffs, it will not hurt your open differential.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #3 of 11 Old 05-25-2011, 05:38 PM
Freestyle713
1994 ZJ
75w-140 is more heavy duty, like for towing. what you're supposed to use is 80w-90.
Freestyle713 is offline
post #4 of 11 Old 05-25-2011, 06:40 PM
melk
I put 80w-90 in both my front and rear diffs.
melk is offline
post #5 of 11 Old 05-25-2011, 07:08 PM
Freestyle713
1994 ZJ
just ordered 3 quarts (1.75q front, 2.25q rear, or 1.25/2.75 cant remember) off of amazon for under $30. it was $11 a bottle in advance
post #6 of 11 Old 05-25-2011, 07:11 PM
TallyZJ
How much shipping do you pay?
TallyZJ is offline
post #7 of 11 Old 05-25-2011, 07:33 PM
Freestyle713
1994 ZJ
it was $10 but surprisingly it was still cheaper than buying it from the store. by like $5-$8. so in my mind its worth it
post #8 of 11 Old 05-25-2011, 07:43 PM
TallyZJ
Yeah, but, personally I would have spent that in my local community instead. Not kicking you for it at all. That is your choice.
TallyZJ is offline
post #9 of 11 Old 05-25-2011, 07:51 PM
Freestyle713
1994 ZJ
well in that case, im paying the fed ex guys, lol. plus its not really my community. its down the road a bit in the next town and thats where i bought some paint, brake cleaner, and the differential gaskets anyways. if it was my local napa, then i would have spent the money there cause there nice guys and i go in there all the time. and on a side note, it wasnt the same brand gear oil. advance had lucas, the one online was valvoline high performance.
post #10 of 11 Old 05-25-2011, 08:44 PM Thread Starter
lexo1014
I havent put it in yet as im giving the rtv a night to form a good seal,,so should i take the 80/140 back and get what just regular 80/90?
I usually have a company truck, so i dont drive much but that may change and i may be putting some decent miles on this vehicle and im just looking for good lubrication and protection
lexo1014 is offline
post #11 of 11 Old 05-25-2011, 08:47 PM
Candymancan
the 85-140 you found is fine, i used it to fill up my rear diff as it was a little low.
Altho i would use a bottle of friction modified from the dealership if you are replacing all the fluid.. I dont think that bottle you found actually has friction modifier in it i dunno, if its the same bottle i used mine didnt mention that it had it in it... only that it can be used in limited slips
Candymancan is offline
Which Diff Lube (not brand)... Im confused... 3fifty ZJ Grand Cherokee Forum 2 09-28-2007 09:14 AM
DW and toe-in: Clarification? husker_zj ZJ Grand Cherokee Forum 4 10-08-2006 10:41 PM
Amsoil Full Synthetics! Anyone run their T-Case or Diff lube? Polaris Junkie ZJ Grand Cherokee Forum 8 08-25-2006 04:15 PM
Need some clarification OffroadZJ ZJ Grand Cherokee Forum 7 02-17-2005 11:11 AM
