Diff. help - JeepForum.com
post #1 of 4 Old 08-01-2003, 11:35 PM Thread Starter
bugman53
Diff. help
i have a 1994 JGC with 145k the only problem is when i turn the wheel it kinda wont’s to fight me just a little but then it make a clunk sound and it frees up. It feels like the diff is unlocking or something? Did someone put lockers in it. possible VC? Also how do i know if i have limited slip or not. I am pretty sure both wheels spin.
Sorry but one more question my jeep wont’s to wonder and daunt wont to stay strait some one said adjust the steering box. Is it just worn tie rod ends or something.
1994 Grand cherokee 5.2 v8 fully loaded, Stock for now........
bugman53 is offline
post #2 of 4 Old 08-02-2003, 02:15 PM
RockPaws
RockPaws's Avatar
If you have a limited slip rear diff, this will happen. It usually wants to push forward while your trying to turn. It will scrub the tires a little more. I never heard a clunck, maybe a chadder. If you do have LS make sure you have the friction modifer added to the gear oil. I recomend Red Line 85w140 gear oil for the ZJ rear differential. It comes with the friction modifer allready inthe oil.
To make sure you have LS, jack up the rear. Parking brake off and in park position. if you can't turn a tire.. its LS.
01' Jeep TJ (Jeep #5)
3.5 RE Custom SuperFlex, Raingler, Kilby, Currie, Banks, Borla, American Racing, Custom mods, Always more in the works.
RockPaws is offline
post #3 of 4 Old 08-02-2003, 02:20 PM
RockPaws
RockPaws's Avatar
as far as the steering wonder. Check out the system while someone tirns the steering wheel back and forth about a 1/8 of a turn. This way you can inspect the steering system for any movement. I have found the first part to go out is the track bar. If its the steering gear box, I haven't had much luck adjusting them on the ZJ. usually just replace it. If its in need of replacement, replace the pump and hoses at the same time.
RockPaws is offline
post #4 of 4 Old 08-03-2003, 12:19 PM Thread Starter
bugman53
Thanks for the help
bugman53 is offline
need help with switching stock rear diff for a limited slip diff jbearss04 ZJ Grand Cherokee Forum 4 09-02-2010 11:53 AM
Need help with Diff, oil. SIU ZJ Grand Cherokee Forum 10 11-13-2009 11:00 AM
how to tell what Diff. I have sullivanpunk ZJ Grand Cherokee Forum 4 04-28-2009 03:12 PM
To rebuild a diff or not to repair a diff? Anto ZJ Grand Cherokee Forum 10 03-23-2009 03:13 PM
diff. biff342 ZJ Grand Cherokee Forum 1 03-03-2009 05:16 PM
