diff fluid and transfer case - stealership only ??? - JeepForum.com
post #1 of 21 Old 04-22-2006, 09:30 AM Thread Starter
sanboy
tranny fluid i know is atf 4 + which is basically only at the stealerships.. if you go to a place like Jiffy Lube or ect . they dont care it
what about
Diff Fluid or transfer case fluid changes... is that a stealership product only as well ......... i just dont have the time right now to do it myself .....
this whole " stealership or on your own " because of a certain " fluid " is something i didnt realize before i bought this GC .. in hindsight never would have done it if i knew it was all " properitory" fluids and ect .. makes it a real pain in the a$$$$$$....
thanx for any help someone can give me ..
take care
also any idea in cost and ect
2001 JEEP Grand Cherokee Limited
4.7 - 4x4
sanboy is offline
post #2 of 21 Old 04-22-2006, 09:43 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
You can do whatever brand diff fluid you want. Make sure you add the friction modifier for LSD's. If you have quadra-drive I forget if that needs an additive, check out www.wjjeeps.com
For the tanny, Mobil 1 has ATF+4, which you can get elsewhere.
The only dealership only fluid is the 247 transfercase fluid.
As far a fuel fluid, you will probably have to go to a licensed gasoline dealer
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #3 of 21 Old 04-22-2006, 01:22 PM
JeepsterLR
If yours is a 2001 GC you can use the ATF +3 if thats what came in it from the factory. BUT Jiffy Lube doesn't carry that either. They use Dexron III and some $#i+ they claim makes it +3 compatible.
Valvoline and Mobil make +4 but so far one one here stocks it. I'll make do with +3 for my 99 till they do.
The 247 fluid is reported to be a high viscosity version of +4. Doubt it will ever be available in anything but the Mopar brand since its such a low volume product. But ya never know.
JeepsterLR is offline
post #4 of 21 Old 04-22-2006, 01:51 PM
TJ_Firefighter
TJ_Firefighter's Avatar
i looked this up in my wife's owner's manual last night Dexron III is what is used for the 247.....ATF +3 or +4 for the trans (redline C+ ATF) and the ownder's manual says 75w90 for front diff and 74w140 for the rear plus friction modifier (quadra-drive also)
1999 TJ
4.0L
2" BB 2"BL, ProComp Adj. Front Track-bar, SkyJacker Hydro 7000 shocks
33x12.50 Dunlop RV
Kahki Jeep Club Member #42
U.S.C.G. Jeep Club Member #1
Firefighting Jeep #2
Soon to come: HomeFab Rockers
TJ_Firefighter is offline
post #5 of 21 Old 04-22-2006, 03:38 PM
txtumbleweed
Use Only 247 TC FLuid From MOPAR
Early '99 WJs came from the factory with the wrong TC fluid and the owners manuals are incorrect. Here is the TSB that applies. You should only use the MOPAR fluid for the TC case.
210999 - NV 247 TRANSFER CASE SHUDDER
Date: 06/04/99 (supersedes 211798 dated 12/11/98)
Model year(s): 1999
Description: This bulletin involves a new transfer case fluid, a revised repair procedure, and a change to the Maintenance Schedules "A" and "B".
NOTE: **THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH THE NV 247 TRANSFER CASE.
NOTE: **VEHICLES BUILT ON OR AFTER APRIL 9, 1999 HAVE THE NEW TRANSFER CASE FLUID ALREADY INSTALLED IN THE NV 247 TRANSFER CASE FROM THE ASSEMBLY PLANT.**
Details: A shudder and/or low pitched grunting noise may be present in the transfer case. The condition is a slip/stick condition in the progressive coupling assembly. The condition may be present at slow speeds, and/or during tight steering maneuvers such as parking or backing out of a driveway.
The new transfer case fluid has several different characteristics from that of ATF- 4. Some of those characteristics are: a yellow color, a slightly higher viscosity, and a sweet (new vinyl like) odor. These characteristics may vary depending on how well the transfer case was drained prior to refill.
If a customer describes this condition, perform the Repair Procedure.
NOTE: **THE RECOMMENDED MAINTENANCE INTERVAL FOR SCHEDULED SERVICE TO THE TRANSFER CASE FLUID IS CHANGED. FOR SCHEDULE "A" (FOR NORMAL OPERATING CONDITIONS), IT IS RECOMMENDED THAT THE TRANSFER CASE FLUID BE DRAINED AND REFILLED EVERY 22,550 MILES OR 18 MONTHS. FOR SCHEDULE "B" (OTHER THAN NORMAL OPERATING CONDITIONS), IT IS RECOMMENDED THAT THE TRANSFER CASE FLUID BE DRAINED AND REFILLED EVERY 21,000 MILES.**
Parts required:
2 quarts 05016796AA Fluid, Transfer Case**
NOTE: THE USE OF ANY FLUID OR ADDITIVE, OTHER THAN TRANSFER CASE FLUID 05016796AA, IS NOT RECOMMENDED.
Repair procedure:
1. Raise the vehicle on a hoist.
2. Drain the transfer case fluid as completely a possible. Install the drain plug.
NOTE: **IT IS IMPORTANT TO MAKE SURE ALL FLUID IS COMPLETELY DRAINED FROM THE TRANSFER CASE PRIOR TO REFILL.**
3. Fill the transfer case with MOPAR fluid, **P/N 05016796AA**, until the fluid runs out the fill plug (1.6 liters 1.7 quarts). Install the fill plug.
4. **Drive the vehicle in a safe area and manner. Perform small radius (tight) circles. Even when the shudder condition is no longer present, a minimum of five ( 5 ) left turn circles and five ( 5 ) right turn circles must be completed.
Performing "figure 8s" may be more convenient as long as the circles are small.**
Performing circles in reverse will cause the discs, within the progressive coupling of the transfer case, to move in a direction that is opposite to their movement when the vehicle is driven in a forward gear. This may be of added assistance with displacing the new fluid within the progressive coupling. Drive the vehicle in a safe area and manner.**
Y2K WJ 4.7
txtumbleweed is offline
post #6 of 21 Old 04-22-2006, 03:41 PM
txtumbleweed
ATF 4 Is the Preferred Tranny Fluid Too For WJs 99-04
Here is the TSB advises the switch over to ATF 4.
2100404 - AUTOMATIC TRANSMISSION FLUID USAGE ATF+4
Date: 03/16/04 (supersedes 2100601 dated 6/29/01)
Model year(s): 1999-2004
Description: Information pertaining to automatic transmission fluid usage ATF+4.
Details:1999-2002 Grand Cherokee. A new transmission fluid (ATF+4 Type 9602) has been developed and is being used as factory fill for all vehicles with Chrysler automatic transmissions. Until now, vehicles originally filled with ATF+2 or ATF+3 were to be serviced with ATF+3. Effective immediately, it is recommended that all vehicles with Chrysler automatic transmissions (except for 1999 and earlier minivans) be serviced with ATF+4.
NOTE: ATF+4 MUST always be used in vehicles that were originally filled with ATF+4. ATF+4 is compatible with ATF+3 and can be used to top off vehicles that currently have ATF+2 or ATF+3. DO NOT use ATF+2 or ATF+3 to top off vehicles that have ATF+4 fluid.
Benefits:
Better anti-wear properties
Improved rust/corrosion prevention
Controls oxidation
Eliminates deposits
Controls friction
Retains anti-foaming properties
Superior properties for low temperature operation
Fluid color:
Mopar ATF+4 is a World Class Fluid having exceptional durability. However, the red dye used in ATF+4 is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4 also has a unique odor that may change with age. With ATF+4 fluid, color and odor are no longer indicators of fluid condition and do not support a fluid change.
Y2K WJ 4.7
post #7 of 21 Old 04-22-2006, 04:58 PM
Woody
Retired back to Bowties
Woody's Avatar
1985
Another reason I like my ZJ. I don't have to buy anything from Mopar.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #8 of 21 Old 04-22-2006, 05:01 PM
rrubio
rrubio's Avatar
You can get synthetic if you like.
rrubio is offline
post #9 of 21 Old 04-22-2006, 06:31 PM Thread Starter
sanboy
the question wasnt really answerd
so basically i have to go to a stealership to get the work done .. correct ?
i cant just go to a jiffy lube or ect like 90 percent of the population who drive domestic vehicles
4.7 - 4x4
sanboy is offline
post #10 of 21 Old 04-22-2006, 06:53 PM
Woody
Woody's Avatar
1985
YUP! Remember Chrysler is now Diamler Chrysler and you can't take a Benz anywhere besides a dealer.
Woody
Woody is offline
post #11 of 21 Old 04-22-2006, 07:40 PM
doyll
$teeler$ship is no longer the only place to get ATF +4.
Valvoline is now selling ATF +4 in many parts stores. Kragen and Checkers have it. I think Autozone has it too.
Good Luck!
1997 ZJ 4.0, 42re, 242, 3.73, tow hooks, reciever hitch, skids, OBA, F>R lift, Rancho 9000s, Addco 1.25", JKS discos, 265/75r MTs on stock wheels, 99+ intake, Banks look-alike header, sliders,
NEED: adjustable upper front control arms, front track bar frame bracket for JKS/RE bar, adjustable rear track bar, Addco rear sway bar, winch
doyll is offline
post #12 of 21 Old 04-22-2006, 08:29 PM
Reswob
Wow, you can't even just buy the fluids from MOPAR and do it yourself? Ouch.
'11 WK2 Limited 5.7
Looking for a WK2 full size spare tire and 18" rims
Reswob is offline
post #13 of 21 Old 04-22-2006, 09:28 PM
LEDFoot
Mopar now licenses the ATF+4 fluid so that other manufacturers can sell it. But it's still hard to find. Anytime you see something specifying ATF+3 you should use ATF+4 since it supercedes it.
For your transfercase, if you have Quadra TrackII or Quadra Drive you need the NV247 fluid from Mopar (don't worry, it's not that expensive).
SelecTrac uses dexronIII fluid.
For the diffs you can use whatever gearlube you like. Personally I would go with something synthetic (like Mobil1).
If you tow you should put 75W-140 in the rear, otherwise 75W-90 is fine.
If you have Quadra Drive you should also put 75W-140 both front and rear.
Also the VariLok differentials (Quadra Drive) and the TracLok (optional limited slip rear for non Quadra Drive) requires a friction modifier to be added to the differential fluid.
Also available from the dealer ~$7 each and you need one per diff (remember to put it in _before_ you fill it up with gear lube).
LEDFoot is offline
post #14 of 21 Old 04-22-2006, 10:06 PM
SET2JET
if you don't want to do the work yourself you can get your fluids at the dealer and then take it to jiffy
SET2JET is offline
post #15 of 21 Old 04-22-2006, 10:48 PM
TJ_Firefighter
redline synthetic oils makes "Redline C+ ATF " it is for all fluids ATF+4, mopar 7167 and Mopar 9602...it is a full synthetic, and costs $7.95/quart from summit
1999 TJ
4.0L
33x12.50 Dunlop RV
Transfer Case... What Fluid To Use? torchd ZJ Grand Cherokee Forum 12 01-07-2010 08:49 PM
Diff and trans f case fluid change- Heracles ZJ Grand Cherokee Forum 9 02-24-2007 09:26 AM
transfer case fluid TravisL1213 ZJ Grand Cherokee Forum 9 02-06-2007 01:07 PM
Synthetic ATF, Transfer Case Fluid, Diff. Fluid shel3702 ZJ Grand Cherokee Forum 1 07-05-2004 07:21 PM
NV 247 Transfer Case Fluid DoctorJJ WJ Grand Cherokee Forum 3 09-20-2003 10:36 PM
