Diesel Conversion - JeepForum.com
post #1 of 21 Old 11-20-2011, 02:56 AM Thread Starter
kmm2736
1994 ZJ
Diesel Conversion
I watched a movie called fuel made in 2009. It opened my eyes and got me thinking about diesel. I did some local research and discovered a local Bio diesel pumping station! I have been looking over threads about diesel conversions. It is allot of information to absorb in a day! But I am Dead set in converting my ZJ now! I'm going to start by collecting a engine, T-Case and a compatible transmission. Bellow is my list of possible candidates so far:
Engine - 3.9 4bt (out of a bread truck or something)
T-Case: NP231
Trans: A518 (dodge truck), Allison MD 3060 (truck), 68RFE or AS68RC (dodge)
I'm trying to choose based on performance/driveability considering it will be driven on and off road! Any input or suggestions would be great!
Thanks, Kyle
kmm2736 is offline
post #2 of 21 Old 11-20-2011, 08:35 AM
badbird17x
badbird17x's Avatar
1994 ZJ
Heard good things on the bt. Keep thinking though. In this current gas situation my diesel is parked, yes it gets great mileage, but it costs $1.25 more here. Also have to take in that everything you do to a diesel costs way more. I love my diesel but there is a reason all the manufacturers are selling a lot less of them and a lot more gassers.
If you do it make a build tread, as it will be cool when done. Hell maybe things will be different when it's finished
I like turtles
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #3 of 21 Old 11-20-2011, 08:54 AM
Nimbo
Why do a conversion, when Jeep made the diesel engines themselves? 2.5L TDI
Ever heard of Greenland? It's a "small" island between North America and Europe.
http://tiny.cc/0pb5v
Nimbo is offline
post #4 of 21 Old 11-20-2011, 09:08 AM
badbird17x
badbird17x's Avatar
1994 ZJ
Wish I could find one of those in the states
I like turtles
post #5 of 21 Old 11-20-2011, 10:16 AM
moggie99
It's a 4 cylinder VM turbo diesel - used in loads of Chrysler/Jeep products in Europe, including the Voyager/Caravan/Cherokee/Grand Cherokee. I'm not aware of it being used in any US market models.
http://en.wikipedia.org/wiki/List_of...ngines#425_OHV
Richard Moss
'96 ZJ 4L auto, '95 XJ 4L manual, 2000 Nissan Patrol Y61
In the UK: 1969 MGC GT
moggie99 is offline
post #6 of 21 Old 11-20-2011, 12:36 PM
MN59ZJ
In the US, The KJ Liberty CRD had a 2.5l diesel 4 cylinder. I think there was a WK CRD as well, using a Daimler V6
MN59ZJ is offline
post #7 of 21 Old 11-20-2011, 01:05 PM
somebody5788
1994 ZJ
My buddy is doing this to his Cherokee. Well it could be the Comanchee I don't really remember but either way it's a pretty identical process lol.
2006 Honda 919
1994 Jeep ZJ
2007 Nissan Titan
1997 BMW 328is
somebody5788 is offline
post #8 of 21 Old 11-20-2011, 02:17 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
remember, that 4cyl diesel is HEAVY, a lot heavier than the i6. it is also tall. you need around a 6" lift to fit it. or a few inches of lift and a 2wd beam axle.
ratmonkey is offline
post #9 of 21 Old 11-24-2011, 11:03 PM Thread Starter
kmm2736
1994 ZJ
Hey I did not really think of the weight too much. I really am excited to hear of these other possibilities of engines to find. Now I’m thinking 1.9L VW TDI engine, from 1999-2006 or a 2.8l crd or a Similar sized Diesel motor within my budget. The cost of this conversion is making me think twice on jumping right on the engine swap!
Thinking of deciding on a future diesel and building my zj with the right t case and trans and then swap engine in later.
HPA Motorsports has a complete conversion for tbi but only for the yj, tj, jk.
kmm2736 is offline
post #10 of 21 Old 11-24-2011, 11:10 PM
thirdeye
dannng that sounds super siiiiiiick! If you do it, be sure to post a link here so I can follow it!
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #11 of 21 Old 11-25-2011, 02:58 AM
RTYauch301
I like turtles
that's the same reason my dually is only a tow/emergency vehicle now
RTYauch301 is offline
post #12 of 21 Old 11-25-2011, 07:22 AM
badbird17x
badbird17x's Avatar
1994 ZJ
I had a couple tdi vws. They are great engines, though not a lot of power, and expensive to work on.
post #13 of 21 Old 11-25-2011, 07:35 AM Thread Starter
kmm2736
1994 ZJ
Hey Bad Bird check this page out I found.
http://blogs.jpmagazine.com/6667601/...wap/index.html
"In stock form the VW TDI engine pumps out 100 horsepower and 180 lb-ft of torque, but is said to be easily cranked up to an impressive 165 horsepower and 280 lb-ft of torque with a simple power flash (The factory Jeep 2.5L puts out 123hp and 145 lb-ft). The 1.9L TDI weighs in at a svelte 265 pounds compared to the Jeep 2.5L at 325 pounds. It's 55 pounds lighter than the four cylinder! In the Jetta the 1.9L gets up to 47mpg, in a Jeep it will likely get slightly fewer mpgs because of the Jeeps added weight and increased wind resistance but it should easily hit the 30-40 mpg range with normal use"
kmm2736 is offline
post #14 of 21 Old 11-25-2011, 07:48 AM
badbird17x
badbird17x's Avatar
1994 ZJ
Mine were in beetles. One I had a chip from over seas, strait pipe, it got 50mpg all the time. Problem I had was the timing belt picked up a rock on a gravel road, they are a conflicting engine, so I bought a $1800 head. Luckily I had the dealer do it because 3000 miles later it locked up on a long drive because the dealer didn't torque a line right. Their ins gave me $6000 for the car as that was what a new engine would cost. I bought another and loved it but now have too many kids for a beetle. If it can hook to an ax, and find a way to protect that timing belt, and you could find one under $3000. Then I would lean toward that. Could find a totaled beetle cheap then you would have everything besides the trans.
post #15 of 21 Old 11-25-2011, 10:56 AM
caligiuri87
1994 ZJ
ratmonky is right. size is tricky. i wouldn't even start it to be honoust if u want a diesel get a jeep with an diesel. when i lived in holland alot of jeeps had diesels and land rovers as well.
in fact i KNOW that u can take an old land rover take the complete drive line and dump it in the jeep. ill look up what model my bud had when he did this but it is sweet. knowing that land rover could do about everything.
Shaky.......shaky shaky shakyyyyyyy.....crack boom pow @%^@%@%@$@#$^%&*(^&&%$@!!!!!!
Happy to be a JEEP owner
caligiuri87 is offline
Diesel conversion redneckinutah ZJ Grand Cherokee Forum 12 08-19-2011 10:09 PM
Diesel conversion in 1999+ GC Possible?? bkeast17 ZJ Grand Cherokee Forum 11 08-30-2005 09:03 AM
Diesel conversion CunningLinguist ZJ Grand Cherokee Forum 8 03-26-2005 04:55 PM
GC Diesel conversion gyrusx ZJ Grand Cherokee Forum 4 08-18-2004 08:58 PM
ZJ diesel conversion link eebasist ZJ Grand Cherokee Forum 6 05-20-2004 09:20 AM
